Old 05-15-2008, 09:21 AM   #1
Bronco   Bronco is offline
No damping in rear shock. HELP
I noticed on my way to work today, that my rear shock is feeling very springy. There is no damping any more. Everytime I hit a bump the back tire bounces. I looked and I can't see any leakage or other obvious damage.
Does anyone know how to fix this or do I need to replace it. If I need to replace it where do I get one? My bike it a 2006 Hi Bird 200GY. Please Help!!
Old 05-15-2008, 10:02 AM   #2
liverchip   liverchip is offline
Send a message via MSN to liverchip
I would pull the rear shock and service the suspension linkage with caution. I fount the same symptom with my Xmoto/Jetmoto and found a sheared shock shaft. Dealer supplied me a replacement. No damagewas evident until the rear linkage was out.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 05-15-2008, 04:53 PM   #3
gyjoe   gyjoe is offline
When I had the problem you describe, I found that the rod in the shock had come unscrewed. Had to take the shock apart to put it back together, but nothing was broken.
2006 Lifan LF200GY-5
Old 05-15-2008, 05:16 PM   #4
I'll check this out maybe tonight (if the wife lets me). Thanks for the great info.
Old 05-16-2008, 09:34 AM   #5
Well...I took it apart last night and didn't find anything wrong or loose. It was all tight and the shock unit itself seemed like it was in perfect shape. After I put it all back together I jumped up and down on it and it was working again. After about 5 jumps it started being springy again. Does anyone have any explanations about that?
I think that I may just need to replace it because there is no way to get into it to rebuild it. Now the problem is, where do I get one...
Old 05-16-2008, 09:51 AM   #6
DesertDog   DesertDog is offline
just try and replace it , probly cheaper that way,
if not at least you'll know it was/or was'nt a bad shock
the cost is cheap , shop around 1st
problem is inside the core then
partsprousa.com might have it
DD
DesertDog
