I need a NEW battery for an X22R bike...
Hi Everyone,
I need a NEW battery for my X22R. Can ANYONE recommend a 12 volt battery (THAT WILL FIT) into an X22R holder that I can buy (either) on Ebay or Amazon??? If you can, could you please provide me the link for it??? I'm looking for something between $20-$40 range... Thanks and take care... Joe... ![]() |
Double check the measurements and pole positions but this one should fit. Stock battery is a PM9A-BS.
https://www.amazon.com/Mighty-Max-Ba...21168592&psc=1
Battery for X22R
Hi Jerry,
Thanks... I've been looking for some time and was having problems locating one. One other question, if you don't mind??? I recently blew the fuse (under the seat) and popped in the spare fuse till I could get to the parts store. When I finally got there, the salesman couldn't read the writing on the fuse so he had no idea what I needed. Do you happen to know what fuses I can replace the fuse on my bike with??? Thanks and take care... Joe... ![]() |
It should be a 15amp.
