Old 09-25-2022, 03:21 PM   #1
BD1415   BD1415 is offline
Carb jetting help
I have read countless threads and watched videos about jetting carbs. I can’t seem to jet my new nibbi pe30 on my hawk 250. I changed the pilot jet to a 38 and main jet to 120. When it idles it’s a very high idle. I try to adjust the idle and mixture screw with no success. Anyone out there who can help me get my hawk tuned in?
Old 09-25-2022, 06:47 PM   #2
Wild Dog   Wild Dog is offline
I know it may sound silly, but let's go by the most basic
Did you adjust the idle speed knob?
If Yes.
Is there enough free play on the throttle cable, it may be holding slide up, making the motorcycle idle to high.
Also check that the slide is not getting stuck.
Old 09-26-2022, 01:11 AM   #3
ScoTT250   ScoTT250 is offline
+1 on what Wild Dog said. Definitely check that slide if you haven’t already. I’ve had them seem like they’re in properly but then rotate at the last second. You can still get the cap on but they aren’t all the way down.
By “no success” do you mean you can’t get the idle down or can’t get it to change at all?
Scott
CA High Desert
Currently:
2021 TT250
1981 XL 185 project
2003 Buell Blast P3 (for sale)
Formerly:
1986 Suzuki GS450
1979 Suzuki GS400
1968 Honda CT90
1974 Suzuki TS250
1978 Honda XL175
1997 Suzuki GS500E
Old 09-26-2022, 01:22 AM   #4
Ol,fart   Ol,fart is offline
Ol,fart's Avatar
If Yes.
I would like to add, once you get the idle down then set the idle set the idle air adjustment to the highest rpm(and highest vacuum) then adjust the idle screw again.
2021 RPS Hawk "IKEA" (Came in a box with no instructions)
110 main jet 1washer,2.5 sprockets and the cat fell off( with a little help)
1984 Honda V65 Magna "Daddy's Little Monster"
To whoever stole my anti-depressants.
I Hope Your Happy !
Old 09-26-2022, 03:08 PM   #5
Thank you for the replies. It must have been the throttle cable. I decided to take apart the slide and put it all back together and when I did the idle was much better. I was able to adjust the idle and mixture screw afterwards.
Old 09-26-2022, 07:24 PM   #6
alex_in_az   alex_in_az is offline
what are you using for an intake manifold?
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
