Old 10-01-2022, 05:58 PM   #1
Tomkay44   Tomkay44 is offline
Help getting Nibbi PE28FL right on my 2021 TBR7
Stock exhaust
Stock airbox but chopped open the top for more air and the intake hose is nice & open
Mods:
Ethonal free gas only
NGK Ridium IX plug
Racing CDI box
Nibbi Racing coil
MSD plug boot
17 t front sprocket & off course
The Nibbi PE28FL
I've started with what it came with which is 120 main, 40 pilot, air fuel screw out 1 ½ turns out. It would barely start and would die with any gas. I lowered the air mix screw to ½ turn out and it seems to be good well past ¼ throttle.
I'm wanting to go by Megadan's & China Rider 27's awesome guidance in the thread below that I've been studying on.
http://www.chinariders.net/showthread.php?t=30636
Question 1
It's my understandin the air mix screw should be between 1 and 2 turns out. Since I'm just ½ turn out on the air screw, should I go up on the pilot jet (40 seems pretty high but what do I know), adjust the float needle up 18mm if it's not there already to reduce the fuel in the bowl (is that hard to do), OR should I go with the air screw at ½ turn out, ride around the neighborhood at around 10-20 mph (¼ throttle) and do plug checks (What the hecks a plug chop?) and make sure the color's right.
Question 2
After each plug check, do I just clean the plug with some gas and a tooth brush, dry it out, then pop it in for the next run? IOW, do I need to buy some extra plugs?
Question 3
Besides what's in it, the PE28FL comes with 1 additional #35 pilot jet, and 3 more main jets (108, 110 & a 115). If I don't need a jet kit now, I'll probably need one when I upgrade the exhaust. Do y'all recommend a higher end, more precise set than this one on Kyle Stanford's link off of TBR7.com?
https://www.amazon.com/dp/B07F9MJGJX...SIN=B07F9MJGJX
