Old 05-18-2023, 03:42 PM   #1
J0SH122   J0SH122 is offline
Pentora 230cc problem
So I changed my valves seals and followed the Honda service manual to set timing where u put the cam with the lobes down and light up the line on the flywheels.now the problem I’m having is that it starts but dies.It runs if I keep throttle on it but once I let off it dies.Also when I start it and give it throttle it hesitates a bit.When I let it die it will also sometimes pop.The sound it makes when it dies is like a stalling sound.I think it could be the valve lash too thight.Am I right?or is the timing off even though I followed the steps right?
Old 05-18-2023, 03:47 PM   #2
Recheck valve lash. Also check you that you have all vacuum line connected and/or plugged.
2004 Honda ST 1300
Old 05-18-2023, 03:49 PM   #3
Thanks will do I’ll update tomorrow when I do it,Also I haven’t seen any vacuum lines in mine the only thins I had to connect where the fuel lines and the crank case breather
