Replacing Stock Parts on Assembly/Prep
I've seen on the prep guide sheet and on some thread postings that suggest flat out removing some stock pieces and immediately adding upgraded parts (such as spark plugs for example).
I was wondering if anyone thinks it is worth the extra effort to go a few steps farther. I was thinking of stock pieces I could replace during set up and came up with this list: -oil -brake fluid -filters -plugs and wires -battery -all the stock screws/nuts/bolts for installation and around the carb etc (upgrade to some better quality steel) -o rings (at least lube the ones thats applicable to) -chain -brake pads -cables Am I wasting time/money considering this, or are there some other things that forum readers would replace too? My thought was that by replacing a lot of the "junk" parts that I'll be able to get a head start on preventive maintainance. |
Fuel lines/ rubber hoses...all zip ties
'91 Yamaha Warrior- stage 2 '83 Honda ATC 70 '08 Yongjiang 125cc mx (Loncin) '08 Yongjiang 150cc atv (Jinlong) |
inner-tubes too...
You're not paranoid, you're right on the money brother. ![]()
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
handle bars , cause they have led in theirs,
reweld all weld spots
DesertDog |
#5 | |
Re: Replacing Stock Parts on Assembly/Prep
red,
you sound a little defensive about chinese made bikes. Most new jap bikes are at least 5000.00 |
he said used
My front tube went flat on the road. When I changed it out I could rip it and tear it with my bare hands. I guess it's just my personal opinion but if I had it all to do over again, I'd of done the tubes sooner, not later. I'm not saying that all chinabikes come with dried out inner tubes. Yours might be just fine.
My fuel lines/ vent line started falling apart after 1 tank of fuel.
Tie rod boots on my boys quad cracked and dry flaked after a month of riding... The yamahas boots are still good after 17 years. I love the motor...hate the little things. :twisted:
#10 | |
#11 |
Had the worst luck with tubes in my bike first day out. New ones doing well through the worst stuff I could throw at em.
'09 Kawasaki KLR 650 '07 Zongshen 200cc Dirt Bike K&N cone filter, FMF Powercore Exhaust, Moose Barkbusters & lotta threadlock. |
#12 |
I agree with Red totally, you don't have to go overkill, use your best judgement.. If it looks like it's not up to par, replace it...
06 Lifan 200 GY-5 |
#13 |
Also riding situations should count.
If you are driving in town or next to a town in a populated area...Parts and help are easy to find. If you are in the backountry you will be plenty put out if your tubes blow for no reason, simple little bolt breaks, fuel delivery is compromised ...etc...etc. But then again I was always an eagle scout...or Mcgyver. :wink:
#14 |
Definitely change the oil... The rest does seem overkill, and increases the money you've got into the bike a lot...
#15 | |
Pittsoccer33 Wrote: " My thought was that by replacing a lot of the "junk" parts that I'll be able to get a head start on preventive maintainance." Preventive maintainance is not a bad idea in my book. If you have the money, the time, and you enjoy working on you bike, go right ahead Pittsoccer33. I don't see how preventive maintainance is going to hurt.
