06-03-2008, 10:35 AM | #1 |
Vin Number Location
Ok I got my bike used, and I had a title already in hand when I bought it. So my question is I want to know where Can I find the VIN plate on the Bike. I have a VIN Number on the title, I just want to know if there is one on the bike....because I can't find it..
-2005 Sierra SR200- |
06-03-2008, 11:02 AM | #2 |
Mine was on the right side of the steering column. Try turning the front end of the bike to the left and look between the hinge (I don't know what it's called) between the frame and the forks.
Hope it's there... |
06-05-2008, 09:00 PM | #3 |
ok I look all around the steering column/frame handlebar area and I can not find anything...the only numbers I have found has been a sticker on the engine.
06-09-2008, 12:45 PM | #4 |
Mine is on the right side of the front of the frame by the neck of the forks, in front of the tank. Also on a sticker on the swing arm back by the rear tire. You should go by the one on the frame though.
06-09-2008, 12:50 PM | #5 |
Mine is stamped into the frame on the steering tube. And the sticker is on the swingarm.
Allen
06-09-2008, 02:11 PM | #6 |
Same here. Mine is stamped into the frame on the left side, and a metal plate with the VIN stamped on it is riveted to the right side of the same tube.
When everything has left you, you are alone. When you've left everything behind, there's solitude.-Schiller |
06-09-2008, 10:03 PM | #7 |
Thanks guys I fouind it....It is stamped into the tube...the whole time I was looking for a plate....
