Old 03-30-2024, 03:54 PM   #1
Templar owners, lowering strategies
Can you post in this thread a photo of the lower legs of the shock (connected to the linkage). On the X, the legs are a couple of inches longer than needed, which allows drilling new lowering mounts. We are wondering if there is room for drilling new mounting position to "shorten" the rear shock like you can do on the X.
Also, does the M have a removable set screw to remove the muffler tip. It's on the Standard Templar, but not the X. Photo please!!
Old 04-01-2024, 02:15 PM   #2
Aussie_in_MO   Aussie_in_MO is offline
Thumper, the lower end of the rear shock is visible in the Xpro assembly video on YouTube around 25min, 30 seconds. Looks like there may be enough room to drill?
Rear suspension at 10min 18sec, in this one and there's also a couple of shots of the muffler at 9min 50 sec (not seeing a set-screw) in this video:
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
Old 04-19-2024, 12:19 PM   #3
Twowheeler   Twowheeler is offline
My '22 M, Bought 3/'23
This is the bottom of my rear shock from the right side. Not only is it totally different than the X, I cannot get my spring compressor on safely, to replace it, and no one within 80 miles of me, will work on Chinese bikes.
ID:	31283   Click image for larger version
ID:	31284   Click image for larger version
Old 04-19-2024, 03:19 PM   #4
Finally. THANK YOU, two wheeler, and Aussie (from April 1st)!
It looks exactly like the lower connection on the Templar X. The person that "answered" my question about room for another mounting position must have been looking at the upper mount (no room at all!).
I am sure you can drill a lowering position, and it will work the same as it does on the Temp X.
Here is post #33 from the Templar resource thread. There is a link to the full description of how to do it.
https://www.chinariders.net/showpost...4&postcount=33
I think ~7/8" will give you 2" or maybe a little more. 1" gave me close to 3" drop on the 6 speed Templar X. I am sure the linkage is identical.
I will find out once I get my son's Templar M, whenever they are back in stock!
Old 04-19-2024, 04:02 PM   #5
(video link- shown above)
Thanks Aussie, YES, the videos definitely show the lower shock mount legs, and the access plug for removing the muffler insert on the M.
THANK YOU!
I am confident that the M has the exact same shape on the lower mounts for the rear shock. Two Wheeler's photos are kind of dark, but suggest the same.
As for the muffler insert, I'll explore this when I get my son's new Templar M. A spark arrestor replacement might open up the flow and provide a larger diameter USFS approved spark arrestor anchor.
Old 04-20-2024, 12:08 PM   #6
Standard Lowering Link
I ordered a lowering link for the KTM. THe lower mounting position does have room for an additional hole. epending on how this goes, I might do that instead, or in addition to the link. They say 10-30cm, depending on the model (it's good for many KTMs, Husqvarnas, others).
I will measure the link on the Templar and compare these, including the original KTM link. They might be identical in the bushing diameter and length. Or they might be compatible with a washer or two.
While they are out, I can measure the dog lengths, then measure height before and after to see how much lower it really is. I will post results here in this thread.
Old 04-22-2024, 04:22 AM   #7
My 2022 Templar M (Buyers Remorse)
[Quote]I am confident that the M has the exact same shape on the lower mounts for the rear shock. Two Wheeler's photos are kind of dark, but suggest the same.
Sorry about the pics. I didn't have much lighting. My M, has a totally different rear shock design, than your X. I looked at your pics. I saw how you did it. The bottom fork is thicker just above the bolt, making it impossible to drill a hole safe enough away from stock hole. I would just replace the whole shock, but can't get my compressor on good enough, to safely remove it. It's a tight space. I bought the exact same compressor that you had and bent the tabs in, but did not have a way to cut them. These pics are from the Xpro site. Between my phone and my shaky hands, I could not get a better photo. The left one is M and the right one is X.
ID:	31312   Click image for larger version
Old 04-22-2024, 09:19 AM   #8
Oh. That thickening isn't obvious in the video either. If I can ever buy a Templar M, I will take a closer look.
I do have the lowering link on the way. It's supposed to fit the KTM, probably incompatible with the Templars, but I will take measurements anyway.
You should be able to remove the rear shock. Just unbolt it and drop it out the bottom, can't you? No need to compress it. There is just one bolt at the top. Linkage should swing out of the way.
Old 04-22-2024, 09:31 PM   #9
I will try. But I cannot find a shorter one to replace it. Man, I could kick myself, for not getting the X. I changed my mind halfway trough my layaway, and bought the M. Oy vey. I was going to post a video of my delivery, etc., but never did. Long story, but R and L driver, never secured it and I had damages. Everything is fine now. PowersportsMax people were awesome!
Old 04-22-2024, 10:09 PM   #10
"but Rand L driver, never secured it and I had damages. Everything id fine now. "
Translation...?? "R&L driver never secured it, and it had damages..."
Is this correct? What damages?
There may be other ways to lower it. Glad PSM took care of you.
Old 04-23-2024, 09:56 AM   #11
GypsyR   GypsyR is offline
GypsyR's Avatar
R&L wasn't kind to my Templar either. Powersportsmax really stepped up though.
Old 04-24-2024, 01:51 PM   #12
Too much to go into here. I'll post pics, etc., asap.
