Old 02-01-2007, 12:17 AM   #1
Vlad   Vlad is offline
Lifan LF200 chain and sprocket info?!
Hi people, I just got a Lifan LF200 bike and the top speed is not where I want it. Im thinking of doing a sprocket changeover to get more speed, but Im not sure if the chain is 428 or 520. Also does anyone have any recommendations as to what sprockets I should use to get a higher top end...
Old 02-01-2007, 02:38 AM   #2
msRandi   msRandi is offline
Send a message via AIM to msRandi
there are a lot of posts about sprockits. 17 front and 45 rear works well for us. it lets go about 68 mph and still has alot of power.
Old 02-01-2007, 09:13 AM   #3
You have the 428 chain, but you can switch to a 520 with a little bit of modification to the front sprocket case, from what I understand. The GY-5 LIfan model has a stock 46 t rear and 17 t front sprocket which is good for around 70+ mph according to the owners of those bikes. If you have a GY-2 model, not sure what the stock set-up is. The other brands, that are manufactured by Lifan, but that have their own names have various combos, the most popular seems to be a 56 t rear/14 t front.
If you were hoping to get more than 70 mph as your question is a little vague (you don't mention what speed you are currently getting) you won't see it out of the GY enduros. 70-75 (mph) is about the tops.
Old 02-01-2007, 11:03 AM   #4
liverchip   liverchip is offline
Send a message via MSN to liverchip
In know this is a dopey newbie question, but when you mention a 520 vs a 428 chain, does this reference the tensile strength or the size, or both, and is there an easy way to ID one's chain?
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 02-01-2007, 11:27 AM   #5
The main difference in chains is the size (width), the 428 being smaller (narrower) than the 520. Not sure if tensile strength is different, but fairly certain its not. Someone had posted the differences in width size a few months ago, so if you research the threads, you might be able to find the sizes, or if someone knows them off-hand, your knowledge is needed right about now...
Old 02-01-2007, 11:32 AM   #6
Part of the question can be answered above in the "Sticky:chains 101"
And here is a post to describe the differences:
http://chinariders.net/modules.php?n...ghlight=chains
Old 02-01-2007, 11:42 AM   #7
This was a quote from a post a few months ago regarding chains on a different thread. This is from member 'Fashby'
"The pitch is the distance between the center of the rivets of the chain. It is .5" for 428 chain and .625" for 520 chain."
-- Fashby
Old 02-01-2007, 11:52 AM   #8
So a sprocket change is also necessary when upgrading to a heavier chain.
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
Old 02-01-2007, 12:22 PM   #9
red2003   red2003 is offline
If you are going from the 428 to the 520, yes you need new sprockets too. If you just want a better chain, get a HD 428 like from DID.
Old 02-01-2007, 12:42 PM   #10
red2003 gives a good opinion as far as compromising. A conversion to a 520 chain would give you a theoretical stronger chain, and open up the sprocket choices a bit, but you would need to do some work to get it to fit at the front.
On the "sticky: chains 101" member Fatboy250 said that he ordered a 428H 126 chain that had the correct number of links to fit his 46 t sprocket, and the "h" stood for heavy duty.
Old 02-01-2007, 01:09 PM   #11
Well, not exactly. The first # of a chain size dictates the pitch. The pitch is the distance between link pins (length of the link center to center). The pitch is in 1/8's of an inch so a 4** series chain is 4/8 or 1/2 in. between links. A 5** chain is 5/8 between links so the problem with going from a 428 to a 520 chain is not the width (actually the 428 has a WIDER sprocket) its the length of the links. That's why is wont line up on the sprockets. The last 2 numbers dictate the width of the link (inside) in 1/8's of an inch. So the 428 is 2.8/8 wide and the 520 is only 2.0/8=1/4 wide. So a 428 chain has shorter/wider links then a 520 chain. Keep in mind the overall width of the 520 is probably larger since the actual links are bigger, that's why they are a stronger chain, metal for metal. I'd stick with the 428. These bikes don't have that much power and a 520 chain is A LOT heavier. Thats rotating mass you're trying to move and it's gonna rob even more power.
Old 02-01-2007, 01:43 PM   #12
Thanks for clearing that up. :oops: On one of the threads I had linked to above (from a few months ago), one of the members was recommending going to the 520 chain, and after reading Fatboy250's response a couple of weeks ago re: his aftermarket 428 heavy duty chain, I thought that when I am on the road again, I would go with this same 428 chain. You seconded it for me today and the weight issue is one I hadn't even considered. Thanks!!
Old 02-01-2007, 01:53 PM   #13
No problem, man. That's why we come here to share knowledge! I think a HD 428 is more then ample strength for what these bikes will ever produce. I doubt seriously you could break the stock 428 with 16 hp. Look at the 450F racers. They are running 4 times the HP on a 520 chain, so I don't think we're gonna hurt our little 428's Rock on :!:
Old 02-01-2007, 06:20 PM   #14
Awesome guys thanks. We ought to move this information to the chains 101 area as I don't believe that the sizing nomenclature is discussed. I had read through it and not found the answers I was seeking. The pitch and width info is great. BTW I will be sticking with the 428 as well.
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
Old 06-09-2007, 02:03 PM   #15
halfpinoy007   halfpinoy007 is offline
CHAIN
RED 2003 IS CORRECT! More rotating mass will rob power, but yes! I snapped my chain as soon as i installed my racing engine! So i had to buy the HD D.I.D. chain for my bike and NEVER had problems ever again! It also boasts low stretch so that you dont have to adjust it every week! I adjust mine only every 2 weeks now.
I sell this chain in my website, will fit most chinese bikes and its a tru-roller design for less friction than stock...as a matter of fact after i installed the chain i noticed a significant increase in low end power bc of less stretch.
