Old 06-07-2008, 08:32 PM   #1
Matthew04833   Matthew04833 is offline
Battery won't keep charge
I have a gy-5 and the battery goes dead after a few days when starting it. I think it might be the rectifier... Anyone have any Ideas???
Old 06-07-2008, 10:21 PM   #2
warrior91   warrior91 is offline
other than testing the battery, and replacing stock batt. NO.
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 06-07-2008, 10:35 PM   #3
katoranger's Avatar
I gave mine a good charge with a charger when it did the same thing. That was over a year ago and I haven't charged it since.
Alot of the stock batteries are no good though.
Allen
Old 06-09-2008, 09:23 AM   #4
Hmanfl   Hmanfl is offline
Re: Battery won't keep charge
Buy a cheap Volt meter if you don't have one already.
Buy a good 12v battery charger if you don't have one.
Check the voltage on the battery when its dead and after charging
overnight. Just to see how much it changes or if it's dead
to begin with.
Should charge up to 13vdc , then it should stabilize around 12.8vdc
Don't charge it at more than 2 amps charge rate overnight, let it slowly
charge back up.
Pull the spark plug out of the bike. So the Bike will turn over easy,
But not start.
Get someone to help you if you can, disconnect the rectifier white plug.
Use the wiring diagram for Lifan's, see sticky at top of Dual Sport forum.
(To do these checks, use the volt meter to check voltages inside the white
plugs, in and out)
Check to see that you have voltage coming out of the magneto, should be
12vdc at least, I think it will be higher and maybe AC instead of DC, check for
both. Check to see if 12vdc is coming out of the rectifier.
If you have the time to let the bike be down for 2 or 3 days and don't want to
do the checks listed above, just pull the battery out of the bike, charge it
up overnight, then let it sit , un-used for 2 or 3 days. If the voltage drops
back down to under 12vdc in that time then its the battery.
If the battery is 2 or more years old, consider replacing it first as it is the
cheaper of the two things to fix.
2007 Komoto GY250
Unipod Filter, 115 Jet, Battery Under Seat, 17/40 Sprockets, Duro Tires - 1500 Miles
Old 06-09-2008, 11:23 AM   #5
katoranger's Avatar
I have a walmart charger that has the 2amp setting. You don't want to use more than that.
I charged mine overnight once after getting the bike. It was the first day I had it that it wasn't holding a charge. After a good charge it is still going.
But others have had bad batteries out of the box too.
Allen
Old 06-09-2008, 11:28 PM   #6
Komoto250cc   Komoto250cc is offline
Bought a new battery
I bought a new 12v interstate battery for mine and it is awesome. My chinese battery was a peice of crap. Just buy a new one.
