06-10-2008, 09:37 PM | #1 |
Hi-bird 250cc NightHawk clone fuel issues
Having fuel delivery issues. Carb seems to be getting fuel fine. Changed the c clip on the pin across the board. Engine starts, idles sometimes, but seems to cut out after revving past 4k rpm. Any suggestions? Jets seem fine and clear.
06-11-2008, 06:20 AM | #2 |
if the float bowl and jets are clean, then it could be a ignition issue. does that machine come with some shipping gel in carb?
06-11-2008, 08:18 AM | #3 |
Bowl and jets are clean. Seem to be spark fine. We pulled the spark plug and ran the starter for a bit and couldn't smell hardly any fuel in the cylinder.
06-12-2008, 06:06 AM | #4 |
sounds like you need to give a call to the outfit you purchased the bike from. they might have a handle on the problem, and save you hours of investigation.
06-12-2008, 11:29 AM | #5 |
I think you have a carb problem with it not getting enough fuel for high rpm.
Did you run a fine wire through the jets? It may be just one small speck of dirt plugging it. There is a carb break down sticky in the dual sport forum showing all the parts. It doesn't take much for it to plug. Also when you moved the c-clip did you move it toward the pointed end? Allen
06-16-2008, 09:03 AM | #6 |
Took the carb completely apart and cleaned it with carb cleaner. SEems to work better. Will see after a couple days of riding.
Thanks! |
06-17-2008, 03:35 PM | #7 |
You could add a fuel line filter, it might help
06-17-2008, 06:38 PM | #8 |
it already has one. Still having a couple of issues. Seems to be inconsistant on fuel delivery. Although I was able to ride it around a bit finally
06-17-2008, 06:41 PM | #9 |
Is the choke operating correctly?
Make sure it is not sticking. Allen
06-17-2008, 09:24 PM | #10 |
Also your float bowls migh be sticking??????
06-17-2008, 09:46 PM | #11 |
both seem to be operating fine. When cold, I can rev it up to about 5-6k and let it down fast and it sometimes dies from this... Also I cannot seem to get it to idle below 2k or so,
06-17-2008, 10:27 PM | #12 |
I think you are too lean. Will it run better slightly choked?
Allen
06-18-2008, 05:31 AM | #13 |
maybe the tank petcock itself has some crud in it blocking the fuel flow.. that might be worth chasing down. also with the idle at 2k it sounds like a sticking throttle or slide not allowing the carb into the idle jet range.
06-28-2008, 11:02 PM | #14 |
If there are this many problems with fuel delivery. I would dunk the carb, and buy a rebuild kit. Rebuild kits do wonders, carb parts can look clean, but they are sometimes deciving.
PS: Or it could be bad gas remember KISS.
<div><a href="http://www.youtube.com/watch?v=X2ilH...s</a></div><br /> |
06-28-2008, 11:11 PM | #15 |
How many miles are on the bike?
