06-12-2008, 12:17 PM | #1 |
mixture screw
I tuned my bike up last night using the throttle chop method. I turned the air fuel mixture out 1.5 turns of the total three runs. went out to start it this morning and was amazed at the difference it made.
I already set the c-clip down and it helped a little. However this helped more than anything I have done. it also accelerates much better. when my kansas weather eases up I will check out the top speed and see if that has changed much. 1,600 mi and
ALONZO 2007 Lifan a.k.a lucy lu. 2,000 miles of good riding. |
06-12-2008, 01:28 PM | #2 |
Cool, that's good news. The top speed should not be effected at all with fuel screw and or needle clip adjustments. They only effect off idle through 3/4 throttle performance, not WOT.
06-12-2008, 02:54 PM | #3 |
WOT was uneffected 5th gear@ 7,000 rmps is about all she can pull. how do I improve the WOT? sure would like to see 70 MPH
as for idle to 7,000 the bike has improved. |
06-12-2008, 06:05 PM | #4 |
If you are topping out in 5th, then that's all your sprockets will handle.
If you are going up hills easy and the wind doesn't effect your top speed then you can get a larger counter sprocket or a smaller rear sprocket. That will increase top speed but decrease your torque.
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
06-12-2008, 06:40 PM | #5 |
hey all... a quick question.... does turning the mixure screw in richen or lean off the mixture?? Thanks for ya help.
BTS GY125: 30mm Mikuni carb - 110 jet, fully gutted exhaust, Xian filter and AMR Stage 3 CDI = 74 MPH |
06-12-2008, 07:09 PM | #6 | |
As for the mix screw I belive that turning out "left" richens the mixture. my plug was carbon white and after turning to the left it turned a nice golden brown. white is too lean brown is good blackened is too rich |
06-12-2008, 08:12 PM | #7 | |
06-12-2008, 10:35 PM | #8 |
I think with the pod filter and a larger main jet you will increase your topend alittle bit.
You may be geared too tall for the engine to pull the bike in fifth. I can run at 8500rpm in fifth. Before the jet and filter it was 8100 rpm. Allen
06-13-2008, 12:32 AM | #9 |
Kato says it better than I do. :oops:
06-13-2008, 09:01 AM | #10 | ||
06-13-2008, 09:04 AM | #11 |
Turning the mix screw in/clockwise will lean it out.
06-13-2008, 09:22 AM | #12 | |||
You will see that I said exactly what you said, but differently. Furthermore, I don't just take the time to read what you say Red2003. I cut and paste your stuff stuff to my own personal repair folder. I've found red, that you ride me pretty hard even when I regurgitate what you have already said verbatim. Even when I cut and paste stuff that you say, to back up my statement. I tried very hard to be clear, red. I not only read your post, I re-read it, then I cut and pasted it in to prove what I said to him was valid. Then I typed out what you said in newbe for the guy. (With a burnt left hand and I might add, yes I'm in pain, but I wanted to help the guy.) Please read my post again, I said exactly what you said and got hammered, again. Sorry alonzo none of this helps you. Don't listen to me, red is right. I'm just a newb. |
06-13-2008, 09:31 AM | #13 |
Meow The Claws Are Out Hiss Hisss LOL
06-13-2008, 09:57 AM | #14 |
Nah, no claws. I am not riding anyone. Iron Fist, I didn't realize I was riding you at all. I don't remember ever even responding to one of your posts before. It looked, and still looks like you were correcting me, which is absolutely fine if I am wrong. If you were just restating what I had already said, I don't see the need. Seems kinda redundant. No harm, no foul, no worries. I'll be more careful in responding to your posts in the future. Sorry to stir the pot. I miss Porterz..................
06-13-2008, 10:02 AM | #15 |
