Old 07-10-2008, 02:11 PM   #1
jwe   jwe is offline
08 AL GY-5 from motoxtreme + my experience so far
Chronology (after many weeks of online research):
THU 6.19.08 11:00am - emailed Brian @ motoxtreme.net with a few questions
THU 6.19.08 2:42pm - received response from Brian
FRI 6.20.08 2:30pm - Ordered (paypal) 2008 LF200GY-5 from Brian @ motoxtreme.net
SAT 6.21.08 9:33pm - Confirmation of payment received from Brian
FRI 6.27.08 4:30pm - Called Brian to check status of order, he said it was on its way
THU 7.03.08 3:15pm - GY-5 Received
THU 7.03.08 5:00pm - Emailed Brian inquiring about assembly instructions
THU 7.03.08 11:20pm - Assembly instructions received
FRI 7.04.08 9:00pm - Assembly completed, including bike PREP (locktite, oil change, etc)
SAT 7.05.08 10:00am - First Ride = SWEET :!:
Issues:
* Bike wouldn't start initially without moving the throttle a very small amount,
adjusted idle screw to no avail, adjusted throttle cable near throttle, starts easier now
* Choke cable was broken - see image
* Seat does not bear Lifan name - see image
Issue Status:
* Bike doesn't always start easily, but it appears to do better each time
* Waiting for new choke cable (not really needed yet)
* Still discussing seat issue
* Waiting for Paperwork (anxiously )
Comments received:
* Wow, it looks better in person than it did in the pictures.
My Status:
* So far I am very happy, haven't been able to test it out too much, since there is no good place to ride until I am able to get tags. Can't wait to put some more miles on it (or is that kilometers )
Old 07-10-2008, 03:06 PM   #2
rldesq   rldesq is offline
Got mine from Evo Sales and didn't have the Lifan name on the seat either, looks like you have the same seat I do... don't know what that means if anything.
I sent a PM on the assembly instructions, thanks.
Old 07-11-2008, 12:04 AM   #3
alonzo   alonzo is offline
congratulations :!: :!: :!: :!:
Lifan is a very good bike. Ordered mine through Brian. the bike has been very solid. Do the c-clip mod trust me it is worth your time.
I have had two real issues with my lucy lu. I took her off roading and hit the rear brake to turn. somewhere I lost a bolt that I installed. opps :oops: wrapped the drum around the axel.
then some under paid worker put the relay on the wrong way and I was without electric start for two days.
well lucy lu now has 2,500 miles on her and I ride her harder every day.
watch your nuts and bolts and enjoy the 4.99 per gallon gas prices.
ALONZO 2007 Lifan a.k.a lucy lu. 2,000 miles of good riding.
Old 07-11-2008, 12:16 AM   #4
oh yes another suggestion I posted for another user here. get some die electric grease on the starter connecters. I just had to clean a whole lot of crud off my starter connecter it will save you trouble down the road.
Old 07-11-2008, 12:27 AM   #5
dieselhead   dieselhead is offline
I second the E clip mod, drop it to the bottom, and you will never need the choke. Consider a Denso IX 24 iridium spark plug from bike bandit. Starting AND idleing a cold engine is push button instant
Old 07-11-2008, 08:01 AM   #6
jwe   jwe is offline
Thanks guys, Ill give it a try.
So far she is sweet, and everyone I show her to thinks so too.
Old 07-12-2008, 10:22 PM   #7
jwe   jwe is offline
Put the Clip on the bottom today.
Not sure if it helped the starting issue or not, bike was already warm.
Was easy to do though, just took the tank off and did it with the carb in place.
:?: for you GY-5ers out there. If you did remove or cover your BIG #5 how did you do it?
Old 07-13-2008, 02:49 PM   #8
daddy469   daddy469 is offline
I've decided to leave mine. My thought is someone will see it and think "wow, what a dork", but the point will be: Someone will SEE it. Maybe not : /
Old 07-14-2008, 07:46 PM   #9
mtngoat14k   mtngoat14k is offline
I just peeled mine right off. Took about 10 seconds.
Old 07-14-2008, 11:01 PM   #10
jwe   jwe is offline
Mine appears to be UNDER the nice clear coat, so no peeling for me :(
Old 07-14-2008, 11:27 PM   #11
Jim   Jim is offline
Yeah they are cleared over, but you can still remove it... When I had my gy5, I ordered a gy2 headlight fairing, since it was the same, and same red color, without the decals... I believe the blue is different though.
"Be excellent to each other"
Old 07-18-2008, 09:17 AM   #12
jwe   jwe is offline
THU 7.17.08 Received MCO & Bill of Sale
Going to try to get tags today
Old 07-18-2008, 10:39 PM   #13
jwe   jwe is offline
FRI 7.18.08 3:50pm Got Title using MCO & Bill of Sale
FRI 7.18.08 4:30pm Got Tags using Title
Old 07-18-2008, 10:56 PM   #14
jwe   jwe is offline
Also received green seat from katoranger (awesome to deal with)
So I put it on the GY5, took at pic, and photoshopped (which you can tell if you look closely) the rest of the red plastic green and made the white plastic black.
Hope to do this for real someday, but it probably won't look this good.
Old 07-19-2008, 08:30 AM   #15
katoranger's Avatar
I was thinking no one would want that green seat.
Allen
