07-21-2008, 02:25 PM | #1 |
New owners BEWARE!
Hi everyone, I'm new to the forum. Got a lifan from hooper imports via Truck shipment, put it together via all the forum info - still vibrates a whole bunch but is getting better. (My licence plate bolt holes almost split in two from the vibration.
Anyway, I was doing my best to keep everything tight - and I noticed some new sounds in the front - I thought it was maybe the speedo or something. I was going down the road and luckily not too fast when one of the brake caliper bolts backed into the front spoke, causing the front wheel to lock up and to pitch me off on a major road with a lot of traffic. Luckily I was'nt hurt too bad and was able to ride outta there with a little tightening of that bolt. Warning to all, check the front brake caliper bolts. It could be a disaster if they back out. BTW, anyone have a source for new spokes? I'm gonna need 2 of em. |
07-21-2008, 02:35 PM | #2 |
Apparently, you did not read the Official DS Prep Thread. Brake caliper bolt is on there. I bled the brake fluid and used locktite on the caliper bolts. In my opinion, the brake is the most important system and deserves a lot of attention and TLC.
Chinabikeless |
07-21-2008, 03:20 PM | #3 |
Give Larry a call. I'm sure he'll do what he can to help you out.
1985 Kawasaki Tecate-3 1997 Ural Sportsman 2WD 1980 Yamaha XS1100 2005 TANK Trail 200 2009 Lifan LY110GY-3 (2) |
07-21-2008, 03:47 PM | #4 | |
Miki, Bruce at EJ cycles can help with the spokes. He'll probably ask for you to take a picture of the hub or describe the bike you have.
07-21-2008, 04:49 PM | #5 |
Not the first person to learn a hard lesson, We have all done it.
07-21-2008, 04:52 PM | #6 |
Man, I'm really glad you weren't hurt too bad. Thanks for the warning and tip; I'm gonna check my brake calipers ASAP.
I hope you won't let this shaky start (no pun intended) sour you on riding these bikes. They really are a lot of fun. Take care! |
07-21-2008, 06:31 PM | #7 |
man that sucks. Dont let your bike get the best of ya. I ride the 07 GY-5 and other than my own stupidity I have had no problems. You get the bugs sorted out of these machines and they are really a good little machine.
As for the spokes, make sure and check the rim to be sure the holes are not jacked up. If you have any problems sourcing the spokes, these guys might be able to help you out. they will probably ask you to send them a spoke. . http://www.buchananspokes.com/product.htm |
07-21-2008, 07:03 PM | #8 |
Man thats a danger......I would take the whole front wheel and caliper off the bike and beat it senseless with a sledge hammer......would be well worth it......then I would watch it all burn.thanks for the tip...not too sure but I had a loose screw on my front caliper which I just tightened....I was lucky enough to spot it because my front braking turned to crap.got better after the screw in.Im sure it will come loose again soon.....Im gonna go beat my bike until the turn signals start flashing again1 8)
07-21-2008, 07:12 PM | #9 | |
Get some grade 8 bolts for where the calipers attach to the fork. I pulled mine after 450 miles and it cork screwed out of the hole :!: |
07-21-2008, 07:26 PM | #10 |
THanks for the tip. I forgot to do those...on my way now to do them.
I am happy to hear that you are OK. |
07-21-2008, 08:29 PM | #11 |
Thanks for the encouragement from everyone. I'll try those links you gave me. Even though I'm a newbie to china bikes I've had quite a few in the past, including an XT200 which I'm comparing this one to. I guess I thought that since the bike was in new condition it would have a lot less mechanical concerns than getting a used bike would - Is it worth the money I paid? I guess so.
07-21-2008, 08:31 PM | #12 |
I just looked at my caliper; and I see no way for the bolt to back into the spokes. The bolts are pointing away from the spokes.
Chinabikeless |
07-21-2008, 08:57 PM | #13 |
pic of brake caliper
here's the pic of MY bike for all you naysayers,
and BTW, I read the DS bike prep thread and did tighten everything I installed on the bike -including loctiting the bolts that attached caliper to front shock These bolts came attached from the factory - it was my oversight. After my accident I was considering to loctite them but they have some sort of whitish grease on them - I think it's anti-seize. So I'm afraid to loctite them heres the pic http://picasaweb.google.com/sgudermuth/Skygo |
07-21-2008, 11:23 PM | #14 |
Hey! Great tip! I just went out and checked mine and sure enough both of them were a little loose. Thank you for the info.
07-21-2008, 11:33 PM | #15 |
Which version did you get?GY-2 or GY-5.The GY-2's had an issue with vibration at full throttle for extended times.If you got the GY-2 you may want to reinforce the frame by adding a new piece at the front of the motor.another member on here(porterzcustomz) did that and said it reduced the vibration.Double check and loctite every bolt you can.Welcome and good luck.
yamaha vstar 650,unknown chinese 4 wheeler,johnny pag 250 spyder,lifan gy-5 |
