Old 08-18-2008, 11:57 PM   #1
dieselhead   dieselhead is offline
HEY...Have you checked your EXHAUST INLET Lately???
Holy Smokes Batman, they'v been hittin the saki again!!
The exhaust inlet ID should be about 1" but after they got the collar ring welded on, the ID shrunk to nearly 3/4" counting the HUGE blobs of weld sticking out all around the iner lip!!!!!!!
I just can't help my self, I gotta say it again.....Buyin a China bike, is like a box of chocolates.....................................
And yes, there was a noticable improvement in performance once I ground out all that exrta weld.
I keep tellin my self, but I only paid $1339.00 delivered and "soon" the little things will be all squared away. 38 hours shop time latter, but who's counting!!!
Old 08-19-2008, 01:04 AM   #2
RealHimura   RealHimura is offline
I have wondered, if all the time spent with the tools were office work, would I have enough money to buy a real enduro?
Old 08-19-2008, 01:05 AM   #3
chinaguy   chinaguy is offline
I'm trying to figure out what you mean. Can you post a pic of the "inlet" that you are talking about? How did you grind the weld down? With a file or with a grinder or what?
Old 08-19-2008, 04:35 AM   #4
czowner   czowner is offline
The crappy welding is quite common, some are worse than others. There's a picture of mine after I ground the lumps off in my gallery (page 4).
Jonathan.
Old 08-19-2008, 07:41 AM   #5
tigertamer   tigertamer is offline
Mine's running as fine as you can expect for a 200, so I have no reason to remove the header.
I'll be sure to check it out wen it has to come off 8O
Thanks,
Tigertamer
07 H-D XL883C
06 LF 200GY-5
Yin and Yang
CAUTION
Obey The Traffic Regulation.
Always Wear a Helmet.
Don't Ride After Drinking Wine.
Before Operation, Read The Owners Manual Carefully.
Old 08-19-2008, 09:01 AM   #6
Jonathan.
OK, I looked at your pic and it looks like the collar where the exhaust header bolts to the engine block. What did you use to grind the weld smooth?
Old 08-19-2008, 11:47 AM   #7
elroyjetsn   elroyjetsn is offline
Fun Pipe
Makes no difference if you keep the tiny 1/2 ID "silencer". Replaced mine with a 1" ID aluminum pipe with lots of holes drilled in it.
Gives me enough power to put a smile on my face.
Thumps pretty good, too!
Wayne
Wildfire WF300-SP
Old 08-19-2008, 12:59 PM   #8
Jonathan.
OK, How do I get your pictures to come up in the gallery page? czowner in the search brings up nothing but a emblem.
Old 08-20-2008, 06:18 AM   #9
To grind the weld smooth I used a "de-burring" cutter in an electric drill. It makes a difference when the weld is cleaned up.
To enter a gallery click on the logo or picture.
Jonathan.
Old 08-20-2008, 10:27 AM   #10
THANKS CZ!
Of course, it would be just that simple to get to your photos!! You did a great job getting the ID right in the header mouth. I started out with a 15/16ths drill in a drill press steped up to a 1" then stone grind what little was left smooth. Unfortunately, I didnt do the before and after shots :(
Old 08-21-2008, 05:39 AM   #11
Here's a before picture of a friends bike,
Jonathan.
