Old 09-09-2008, 07:57 AM   #1
ww1putt   ww1putt is offline
Sunl sla 275 cooling problem
We'll try this again. Somehow my original post was deleted. I have a Sunl SLA 265. the motor is a 250cc water cooled 4 stroke. The problem is the water is not circulating. Does anyone have experience with this situation? Where shoul I be looking? Thermostat, water pump, thermocoupler etc?? Thanks for any help you can provide.
Old 09-09-2008, 08:35 AM   #2
Cal25   Cal25 is offline
Look for air in the system maybe.
Old 09-09-2008, 08:23 PM   #3
warrior91   warrior91 is offline
Water pump impellers fell off or drive spinning freely inside impeller...
Typical Problem with china watercooled.
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 09-12-2008, 11:36 PM   #4
VinceDrake   VinceDrake is offline
x2 what the Warrior said. Crapply plastic impellers. Crack and break often, and then no pumping. Remove Therm and start engine. Should *shoot* water out. (Think garden hose, full-bore) If no flow, renew pump.
Side Note: If you have a '96 to 2002 Volkswagen TDI, you have the same problem coming... China hasn't got the corner of the market on crappy water pumps
--Vince
"Sometimes it is better to say nothing, and let people think you're an idiot, than to open your mouth and prove it."
Old 09-12-2008, 11:40 PM   #5
katoranger's Avatar
I replaced a water pump on an F150. The impeller fell off. The MIC replacement pump was actually better built. The previous MIC part was a piece of tin for an impeller.
Allen.
Old 09-12-2008, 11:48 PM   #6
Yurp. Acts just like a head gasket when it happens too!
If it makes you feel any better, The "Made In Italy" and "Made in Germany" units are just as bad.
My 2IC Is German, and I called him on it the other day, after pulling *another* Boned TDI Water pump, with "Made In Germany, VW Audi, GmbH" stamped into it. He said, "Must be a lot of Chinese poeple in Germany these days..."
Just like a German not to take responsibility...
--Vince
