Old 09-21-2008, 10:22 PM   #1
Jim   Jim is offline
Chain / Swing Arm rubber slider?
I'm talking about this piece here:
I'm wondering if there is a better way to set this up, my sprocket and chain are always packed with rubber from chewing through this thing... I'm thinking I need to replace it with some rollers or something, any thoughts or suggestions?
"Be excellent to each other"
Old 09-21-2008, 10:31 PM   #2
chinaguy   chinaguy is offline
Yeah, mine has the same thing. I'm also interested if somebody can suggest something better.
Old 09-21-2008, 10:39 PM   #3
DDG1976   DDG1976 is offline
Send a message via Yahoo to DDG1976
I was told to buy a cutting board from like the Dollar store, cut it to width and counter sink some holes in it for the screws. I haven't tried it yet. I have been looking at some of the roller type tension things on some of the pit bikes to try to adapt. Hopefully somebody out there has "been there done that".
I have all of soberday to satur up!!
Old 09-21-2008, 10:42 PM   #4
Jim   Jim is offline
I'm going to have to go there pretty soon I think because mine looks like it has almost sawed all the way through now, this picture is from quite a while back...
I was thinking the same thing, just have to watch for the top of the chain case cover on the motor if I use a springed roller like on my atv... Hopefully someone else has already got a good solution to this...
Old 09-22-2008, 05:26 AM   #5
tigertamer   tigertamer is offline
I have heard of the plastic cutting board retrofit too.
From what I understand of the stock rubber set-up, the chain cuts in, to the point of contacting the chain rollers. Then the wear becomes more acceptable.
Jim, is your wear to the point of roller contact? If so, does the wear seem to be the same rate?
Just curious,
Tigertamer
07 H-D XL883C
06 LF 200GY-5
Yin and Yang
CAUTION
Obey The Traffic Regulation.
Always Wear a Helmet.
Don't Ride After Drinking Wine.
Before Operation, Read The Owners Manual Carefully.
Old 09-22-2008, 05:51 AM   #6
I think the cutting board is just nylon and that is what you see on a lot of bikes/quads and other vehicles.
It should be easy enough to make one out of nylon and it would wear far better than the rubber.
Old 09-22-2008, 06:32 AM   #7
Jim   Jim is offline
Well I'll see about when I can get a new picture, but that idea doesn't seem to work in reality in this application... My chain and sprocket are always jammed full of rubber, and I think it is almost all the way through that pad now...
Thanks also TC, I'll keep that in mind
Old 09-22-2008, 07:21 AM   #8
chinariderinthesky   chinariderinthesky is offline
what if you used a hifax from a snowmobile track. they are relatively cheap and almost cut to fit. they even have counter-sunk holes in them!
Old 09-22-2008, 10:10 AM   #9
elroyjetsn   elroyjetsn is offline
I used an old Subaru timing belt. Check this thread:
http://www.chinariders.net/modules.p...ht=timing+belt
3000km since, still going strong.
Wayne
Wildfire WF300-SP
Old 09-22-2008, 02:52 PM   #10
Jim   Jim is offline
chinariderinthesky, I'll check that out thanks...
elroyjetson, thanks for the link, interesting, I'll look into that too.
Old 09-22-2008, 05:44 PM   #11
gyjoe   gyjoe is offline
That's what I used; I had some pieces left over from some that had to be cut to fit a snowmobile. They work just fine, but I would think a cutting board would work just about as well.
2006 Lifan LF200GY-5
Old 09-22-2008, 06:44 PM   #12
Counter sinking holes in nylon is extremely EXTREMELY easy.
All you need is a wood drill bit (SPADE DRILL BIT) that is slightly wider than the bolt you want to use.
Mark the nylon and drill your counter sink hole to the depth you want and then change to a regular drill bit and drill the hole to the diameter you need for the bolt to fit thru.
The little point on the spade bits leave you a very nice pilot hole to guide the final drill bit.
I prefer the spade bits that are square at the ends but some have little points to help drill but are not what you'd want for counter sinking.
Old 09-23-2008, 07:06 AM   #13
That's a good trick!
I am fortunate enough to have a set of countersink/drill bits I use for carpentry work :wink:
Jim, if you use the cutting board, I would suggest to use the old pad as a template, to mark the precise hole locations for drilling.
Good luck,
Tigertamer
07 H-D XL883C
06 LF 200GY-5
Yin and Yang
CAUTION
Old 09-23-2008, 08:32 AM   #14
katoranger's Avatar
Wrap tape around the bit at the depth you want to go. Probably about a 1/4".
Allen
Old 09-23-2008, 01:15 PM   #15
If the rollers look brite and shiney, they are likely making contact. But the rubber is so soft, it just compresses and lets the links keep on grinding away. Specially if you have a small rear sprocket that lets the chain pull even harder against the matt.
Wayne
Wildfire WF300-SP
