Old 04-10-2009, 02:19 PM   #1
Stauffer   Stauffer is offline
NEED A STARTER MAYBE!?? help please
hahah you guys always come on right away n tell me whats wrong n all this and that,
its amazing
ANYWAY this is my problem
eltric starter sound like its grinding. rather then starting the bike its just like
REEEARR...RAERRR..REARRRRRCCCSHHHHH and im like uhhhh...
so im using the kick start now which works fine.
just hit 900miles btw.
need to change the oil soon too
anyway
anyone with a link to a new starter or any info giving i would be very thankful!!
Old 04-10-2009, 02:22 PM   #2
Check battery voltage under load, connections, and the starter gearing/Bendix. I bet the starter itself is still good.
Old 04-10-2009, 03:55 PM   #3
katoranger's Avatar
Sounds like the starter bendix may be sticking. Possibly some corrosion not letting the gear slide out.
Also make sure the battery is good and fully charged and that the connections are clean.
Allen
Old 04-10-2009, 09:50 PM   #4
alright so
the eltric start dosnt even work anymore.
its trying to tuirn th engine over and its just grinding it sounds like
and
now the kickstart is acting up.
it wont catch and turn over the engine
i had to popstart it and put put around my work for 5 mins beforei could head out cuz it wasnt warmed up.
please help>>
Old 04-11-2009, 10:47 PM   #5
BillR   BillR is offline
Originally Posted by Stauffer
alright so
and now the kickstart is acting up.
please help>>
Probably moot, but I'd park it until I could pull the starter and see what is wrong. If there are some broken gear teeth, etc, you're grinding that into the engine every time you run it.
If it's due for an oil change, plan on a long day and pull the starter and the spur gear cover. Anything wrong there, I'd also pull the engine covers (clutch and stator side).
I think I have pictures of the stator side with the covers off. I'll find them and post tomorrow.
Bill
Old 04-12-2009, 02:21 PM   #6
This is the only picture I kept from working on my stator.
You can see where the starter gear sits.
And in the upper right corner you can see the starter gear set.
You can check those gears without pulling the side cover.
Left Side Cover view
As far as the kick start not engaging, makes me think that something has broken loose and is lodged in that ratchet mechanism.
Good luck.
Bill
Old 04-12-2009, 08:28 PM   #7
maf119l   maf119l is offline
Send a message via Yahoo to maf119l
Check battery before changing anything.I thought my starter had gone bad,acted same as you described,but luckily my dad tested battery first and found out it was bad.Replaced it and works great now.
yamaha vstar 650,unknown chinese 4 wheeler,johnny pag 250 spyder,lifan gy-5
