Old 06-13-2009, 06:18 PM   #1
smeggy   smeggy is offline
Front Disc Brakes
The cylinder that forces the brake pad up against the front brake disc does not retract far enough to take all the drag off the disc. Is this a brake fluid problem or something else?
Old 06-13-2009, 06:54 PM   #2
katoranger's Avatar
I would flush the fluid out and fill with some DOT 5. Give that try to see if it helps any. If not it is likely that the piston is sticking.
The brake fluid that comes in these bikes is mediocre at best.
Allen
Old 06-13-2009, 11:30 PM   #3
TheRealWorld   TheRealWorld is offline
Most of these will have a small drag on the disc at all times. With the wheel off the ground, spin it and if you can get one revolution that is not to far from normal.
You may not be able to turn it at all but I could not tell form your post. If that is the case do what the katoranger said! A great idea on any new china bike.
Old 06-13-2009, 11:41 PM   #4
AZ200cc   AZ200cc is offline
Three China bike rules.
1, If it's a Chinese fluid drain it and replace it.
2, If it's a chinese rubber product, Replace it soon!
3, If the bolt is put in by a Chinese worker, Loctite it and tighten it.
The oil is probably made from whale blubber, The brake fluid is recycled from sewer water and the rubber will melt if it's ever is exposed to anything but it's natural environment....And the bolts fall out to let You know the bike needs love
Old 06-14-2009, 03:29 PM   #5
forchetto   forchetto is offline
The job of returning the piston back into its cylinder is the rubber seal around the cylinder. This distorts on purpose and acts like a return spring.
The brake fluid under pressure forces the piston to slide out of the caliper. This action deforms the seal in the direction the piston travels. When releasing the brake pedal the deformed seal will pull back to its original shape and pull the piston with it, this action will release the brake pads from the disc.
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 06-14-2009, 04:38 PM   #6
katoranger's Avatar
I just learned something new. Great.
Allen
Old 06-14-2009, 05:40 PM   #7
phil   phil is offline
i would also check the pins on the caliper to be sure they are sliding smoothly your auto parts will have some caliper grease or brake grease, dont use regular grease
halls auto
l
coolster, modcycles, yanmar & zongshen, dealer
fired roketa,lifan and jet moto and apollo quit me who's next
Old 06-17-2009, 03:42 PM   #8
Ma77   Ma77 is offline
at least your cylinder IS forcing the pad onto the disk, no matter what i do to my front brake it never seams to...just......work really :?
Old 06-22-2009, 10:12 AM   #9
smithyUK   smithyUK is offline
strip the brakes rite down to bits remove pistons springs pins ect clean everything thorghly (spelling lol) bave every thing in petrol rince with water let it all dry then reasemble make sure the pistons are totaly clean grese all pins and moving parts (not the pistons lol) finaly get some proper brake fluid into it
good luck
Old 06-22-2009, 10:26 AM   #10
I might be tempted to skip the water rinse!
