Old 06-25-2009, 04:21 PM   #1
undertulsa   undertulsa is offline
Muffler Escaped
Ok guys, i drove across town and the muffler bolt coming out of the engine sheered off, how can i get that bolt out? If you can believe it these bolt were checked and they were tight till the ride, so i didnt locktite them.
honda scematics show that the bolt has threads on each side but how do you screw it out of the engine. Fortunately, the muffler just fell off lost one bolt and the gasket and the pipe joint laying on the road somewhere. I think i can order them at honda store cheeply but the main problem is getting bolt out.
have screw out small enough but what is the normal way to remove the bolt with threads out of the engine that was sheered off?
Old 06-25-2009, 05:04 PM   #2
You can use a screw extractor. A good trick is to use a reverse drill bit to make the pilot hole. Often you get lucky and the stud comes out just like that. CONSIDER taking the bike to a machine shop and letting them do it for you, hopefully while you wait. Cheaper than fixing the head if you screw it up... :roll:
Old 06-25-2009, 05:15 PM   #3
Cal25   Cal25 is offline
Is the stud broke flush with the cylynder? If it is sticking out a bit, you might be able to un screw it with some pliers.
Or maybe use a dremel with a very small wheel on it to cut a slot in it and use a screw driver to remove it?
The gasket and flange are simple enough to pick up at a Honda shop as you suggested.
Old 06-25-2009, 05:21 PM   #4
Good suggestion on the slot with a sawblade or a Dremil. I've gotten away with that trick a few times.
What do the Chinese make these parts out of anyway? Stale cheese?
Old 06-25-2009, 05:26 PM   #5
Look what I found!
http://faq.ninja250.org/wiki/Bodywork_%26_Frame
Old 06-25-2009, 05:58 PM   #6
chrism1   chrism1 is offline
Same happened to me.I think because the pipe system is mounted rigid.A rubber hanger helps alot.The stud was broke flush.Bought a diamond tip dremel bit and picked away.I then drilled and retapped both the next size larger and redrilled flange to match....nice and strong now.
Lifan LF200GY-5
Old 06-25-2009, 08:16 PM   #7
WE got it!!!
My hillbilly brother got the bolt out !!! without hurting head, pair of vice grips!!! Now honda has to order 10.00 of parts and ill be back in business. red locktite this time on the muffler bolts.
:roll:
Old 06-26-2009, 09:27 AM   #8
Alrighty! Glad it worked out well.
