11-11-2009, 08:15 PM | #1 |
Mini ATV front Suspension
Well i finally got some time to get to the shop today with my spare set of mini atv shocks that i won on the auction.
First step was to see if i could lighten up the spring rate a bit as the springs are very stiff on the front end of these little machines. It was a bit tricky to compress the springs to get to that nut but the arbour press came in handy....... Well that made it much easier, i used a big washer that i had cut out of 1/8" aluminum and then cut a slot up to the center, i then used a screwdriver to pry the spring back and inset that disc then the arbour press made easy work of compressing the spring so i could get my 17mm wrench on the nut and then used a 19mm to turn the end off. I found these springs to have way too much preload on them and yeah don't worry about these shocks becuase they aren't, it is a shaft inside a tube and that's it, they work on spring only. I ended up cutting 3/4" off the end ( the one with the tighter spring spacing ) and reassembling the shocks. Before i cut off the springs there was no way in hell i could move these shocks with my two hands pushing against each other, now after removing the 3/4" i can now compress the shocks with my hands 5/8" and my bathroom scale spring rate tester comfirmed this. Before cutting, the stock shock took 95lbs to move 1/2" and 190lbs to move 1", after cutting the rate dropped to 60lb for the 1/2" mark and 120lbs for the 1" mark. So far these results look promising and i'm hoping to get them installed this weekend. I also reversed the direction of where the tight coils were from the way the shocks came, here a pic of the finished shocks and the washer i used to disassemble. I'll keep you posted on my results after mounting on the quad. |
11-11-2009, 08:28 PM | #2 |
Dude since I don't have a press like that in my back yard any tips? :P
11-11-2009, 08:31 PM | #3 |
Yep, a bigger washer than i used, a small tin can or something the fits nicely on the other end of the shock and 2 clamps to compress the spring.
11-11-2009, 08:47 PM | #4 |
Or your friend's hydraulic press.
11-11-2009, 08:48 PM | #5 | |
11-11-2009, 10:13 PM | #6 | |
11-11-2009, 10:47 PM | #7 |
In stock, ready to press. 8)
11-11-2009, 10:51 PM | #8 | |
Need to do something with my Mini Beast front end. I pushed down on the bush gaurd today and the shocks don't move, the axle's and control arm bolt points do. Terrible. The front end on that thing has to be taking a BRUTAL beating on the smallest of bumps at speed. |
11-11-2009, 11:49 PM | #9 |
Bring the shocks over, and we'll see what kind of magic we can work.
11-12-2009, 12:22 AM | #10 | |
Just my thoughts.. it's not a pressing issue I don't think this thing will be doing any heavy riding till next Spring: Other than perhaps me doing 'snow trials' in the street if we get any this year. |
11-12-2009, 12:27 AM | #11 |
Nice waynev.
I have a spare set on the way as well and thats exactly what I'll be doing to them. Pretty intersting about the "fake" shock, but it fits with the machine I suppose. For what it is, I guess springs are alright.
Good, Fast, or Cheap....Pick Two. |
11-12-2009, 01:38 AM | #12 | |
Re: Mini ATV front Suspension
11-12-2009, 02:15 AM | #13 |
A progressive spring will still compress the "lighter" coils first (as intended) whether it is upside down or not.
Where mounting position matters is in high strung applications and thats mainly due to unsprung weight issues, however minor (thicker coil end is heavier than the thinner coil end) but this is meaningless for our application. I'm not going to stress over this one too much since the shock is fake anyway, plus no matter how waynev measured the force required, he did a before and after using the same method and the results showed a milder spring rate.
11-12-2009, 02:38 AM | #14 | |
What would be the point of flipping the coils then? Waynev, did you place the scale on the press base to take measurements?
11-12-2009, 02:42 AM | #15 | ||
