Old 02-18-2010, 12:10 AM   #1
hardy541   hardy541 is offline
Turn signal problem
I have a 2006 jetmoto gy200 and all the lights work EXCEPT for the turn signals. They do not turn on at all and when i check them for a current, there is none. I have checked the ground that is not the problem. Any ideas?
Old 02-18-2010, 01:02 AM   #2
Wild_Alaskan's Avatar
bad flasher?
Old 02-18-2010, 08:34 AM   #3
katoranger's Avatar
I second the flasher. You should be able to find them at a parts store.
Old 02-18-2010, 10:30 AM   #4
X3 on the flasher unit. Go to any auto parts store and buy a new flasher unit to replace the original unit. If the new flasher unit doesn't solve the problem, you can return it for a refund.
Old 02-18-2010, 10:32 AM   #5
ok i will try the flasher but would that cause the lights to not even turn on?
Old 02-18-2010, 11:38 AM   #6
Yep.
Old 02-18-2010, 09:22 PM   #7
do u know where the flasher would be at on a jetmoto?
Old 02-19-2010, 07:30 AM   #8
katoranger's Avatar
Typically undo the seat.
Old 02-19-2010, 11:27 AM   #9
Little black box, 2 or 4 wires, I don't recall.
Old 02-19-2010, 06:38 PM   #10
yea ive been looking for that but i havent found the flasher on the bike yet
Old 02-19-2010, 07:05 PM   #11
katoranger's Avatar
The is a pic of the one on my lifan. It is the box with the white caulk in it. The lifans beeped at you.
http://www.chinariders.net/gallery2/...g2_itemId=5287
Old 02-19-2010, 07:13 PM   #12
Cool. I'm glad someone had a picture.
Old 02-19-2010, 07:15 PM   #13
Check out the For Sale section, Kato is parting out a Lifan...
Old 02-19-2010, 09:10 PM   #14
katoranger's Avatar
I have two that are being parted. Will send you one if you can't find it locally. Mine will beep at you.
Old 02-19-2010, 09:55 PM   #15
thanks for the pic kr . i will let u know if i cant find one locally, ill check after school on mon. b/c im busy this wknd
