04-18-2010, 10:48 PM | #1 |
ever washed your zong? then had to push your zong? twice?
well i washed it and all was well. it started up great then i rode around the yard for 10 mins or so and everything was still great so i took off down the road. i made it about 1 mile or so then it died. it seemed like an electrical problem because there was no spitting or suptering, just all of a sudden like i hit the kill switch. i got it back home and i pulled out the key and there was water on the key, wiped it off then and tried it again, it still had water drops on it. so i opened up the kill switch and got the hair dryer out and dried both of them out off and on for over an hour and it started up fine. i rode around the yard the next day for several mins then hit the rode again. i made about 1 mile or so and it died the same way. i havnt got it started yet, i will try tomorrow. i didn't spay the water very hard around the switches just a little back and forth but i did leave the key in when i washed it. now i am just getting a little grease on the key every time i pull it out. any thoughts? thanks in advance alan
04-18-2010, 11:32 PM | #2 | |
Re: ever washed your zong? then had to push your zong? twice
Diagnosing electrical problems is not fun; however, you will learn a lot from the experience. Here is a link to the thread where I describe the process I followed diagnosing my failed CDI unit. http://chinariders.net/modules.php?n...ewtopic&t=8198 The CDI units have failed on several different chinabikes, not just the Zong. If you don't have a spare CDI unit, I strongly encourage you to contact Phil, or Zongshen America, and get one as soon as possible. Even if your CDI unit is good, you want to have a spare one handy. Besides having peace of mind, a spare CDI unit is great for diagnosing engine electrical problems. I have read that a bad CDI unit can cause damage to your stator. I don’t know if this is true, but I also needed to replace my stator several months after I replaced the CDI unit. I wouldn’t go riding very far until you diagnose this electrical problem, and fix it; otherwise, you could end up stranded in an unpleasant situation. Spud
04-19-2010, 11:58 AM | #3 |
Spud, I was thinking exactlt the same thing. Sounds like a CDI.
Happy to serve. |
04-19-2010, 04:05 PM | #4 |
I'm wondering if anyone has tried the Gio Perf CDI in one of their 200cc Enduro bikes? Put in it my quad find it makes a nice, if minor, improvement. Cheap too, got mine for 15.00 delivered at the time.
04-19-2010, 04:15 PM | #5 |
I don't think it would work, the Lifanoid units are different. IIRC Spud's CDI cost in the neighborhood of $50. I'd also be thinking of a TW200 CDI off Bike Bandit.
Happy to serve. |
04-19-2010, 07:57 PM | #6 |
i have fire at the spark plug, i installed a new ngk also but it still wont crank. im gonna check to see if its getting fuel next and then the filter. the cdi looked good. i think i had the petcock right, i have the long handle aimed down and that is run but what way is reserve? i have ran 100 miles on this tank and i see and hear fuel in the tank when i shake the bike so i dont think its out. both times it died it was just like hitting the kill switch, no spitting at all so i thought it was electrical related. thanks alan.
04-19-2010, 08:02 PM | #7 |
You are out of gas. A failed CDI would usually not spark.
Happy to serve. |
04-19-2010, 11:26 PM | #8 | |||
http://www.cyclepartswarehouse.com/f...009&fveh=28571 Quote:
04-20-2010, 01:19 AM | #9 |
I do find my quads here will run better with a full tank of fuel. Even when it's a little low and not yet empty, they can be a bugger to start.
Wasn't there some talk in another thread about how a faulty CDI will spark sometimes but then fail to spark other times? I believe FastDoc mentioned it.. Maybe I'm still sniffing too much glue. :P |
04-20-2010, 02:49 AM | #10 | |
04-20-2010, 11:45 AM | #11 | |
You might still be sniffing glue, however.
Happy to serve. |
04-20-2010, 05:06 PM | #12 | ||
If I'm not sniffing glue, I might need to start the way things are going for me these days. |
04-20-2010, 05:31 PM | #13 |
Copy that brother.
Happy to serve. |
04-20-2010, 09:03 PM | #14 | |
[/hijack]
04-21-2010, 01:06 AM | #15 | ||
..as for this thread, it's very possible you got the wiring harness wet. One thing I've learned is these chinese wiring connectors and plugs aren't very good. Stuff gets in there really easy. Perhaps some time drying out in the sun is all it needs.. or disconnecting the white plugs and hosing them out with air and some dielectric(sp?) grease/spray. |
