Old 05-27-2010, 09:44 PM   #1
alan566   alan566 is offline
proper chain adjustment?
i believe I'm suppose to check the chain with me sitting on the bike so how do you guys check the chain by yourself?
and when my chain starts getting to much slack and ridding on the that plastic block i will move both adjusters (one on each side of swing arm) one click each, the chain has no slack at all when i sit on the bike. what am i doing wrong?
Old 05-27-2010, 11:31 PM   #2
Re: proper chain adjustment?
Yes, it is best to check the drive chain tension while you are mounted on the motorcycle. I support my bike on a swingarm stand before I mount the bike, then I reach down with my left hand to check the chain tension. If you don't own a swingarm stand, you can get another person to help you check the chain tension. Once you set the correct tension for your weight, you can dismount the bike and note the unweighted tension for future reference.
You should have about 1-1/4 inches of slack in the drive chain when you are mounted on your motorcycle. If you are an average rider, you should have the same amount of unweighted slack in the drive chain as shown in the following video, filmed by forum member CloudRider.
If your drive chain doesn't have any slack while you are seated on the motorcycle, your drive chain is too tight, and you can damage the bearing inside the engine that supports the countershaft. :( It is normal for your drive chain to ride in the chain guard. If you want to learn more information concerning your drive chain, you can read the following thread contained in the Zong Sticky.
http://chinariders.net/modules.php?n...asc&highlight=
Old 05-27-2010, 11:51 PM   #3
Wild_Alaskan's Avatar
also if yo0u have a lifan or lifanoid, check to see if your pivot point is excessively high like on the gy-5s. you will need to run 3 inches of chain slack (not the 10mm as stated in the manual) due to this design flaw to keep from doing damage to driveline components. Or you can do the pivot point modification like i did which moves the swing arm pivot down a half inch. running 3 inches of slack results in a horribly jerky ride and is my biggest complaint about the gy-5 besides the horrible parts support.
Old 05-28-2010, 09:48 PM   #4
thanks guys,
i guess my chain was right to start with, that just seems a little loose to me. i shut off my engine going about 35 mph and you could hear it dragging on that plastic so i though for sure it was too loose. i guess i will put it back to were it was at.
the way i check the chain by myself was to get on the opposite side of the bike (the side the chain is not on) and hold the bike up strait and lean over the bike and put as much weight as i can on the seat with my chest and shake the chain. it just doesn't work out very good sitting on the bike and trying to wiggle the chain and see it also. thanks again for your help. alan
Old 05-28-2010, 09:55 PM   #5
thanks guys,
If you don't have a swingarm stand, your method is a very good way to check the chain tension.
Your drive chain was properly adjusted at the factory, Alan. It is normal for your chain to make some noise if it is properly adjusted. I strongly encourage you to loosen your chain to the original tension. If you travel many miles with an overly tight drive chain, you will surely damage the bearing inside the engine that supports the countershaft. :( If this happens, you will be forced to make an expensive repair.
Old 05-29-2010, 02:20 PM   #6
spud, yea i bought a cheap stand for harbor freight but it looks kinda tall for the bike to me.
http://www.harborfreight.com/350-lb-...and-66552.html
whats the proper why to use this stand? remember i still have the stock wheels and tires.
Zongshen Sierra
Mods: knock off DRC Edge II Taillight , FMF Turbine Core 2 Silencer, Halogen bulb, 18" Wheels, Real Tires
Old 05-29-2010, 05:36 PM   #7
I have that very stand, and I just assembled it and lifted my son's XR200R with it. Make sure that immediately after you jack the bike up, you insert the safety pin. Don't even release the pedal before the pin is in place.
Old 05-29-2010, 05:41 PM   #8
do u use it on the swing arm or under the motor?
Zongshen Sierra
Old 05-29-2010, 05:46 PM   #9
Under the motor. I use a tie-down to secure the bike to the stand, just to make sure I don't knock it off.
Old 05-29-2010, 06:35 PM   #10
Personally, I prefer to use a swingarm stand, Alan. I like my T-Rex swingarm stand very much, and I use it all the time. In fact, I don't know what I would do without it.
http://chinariders.net/modules.php?n...ewtopic&t=7632
The swingarm stand is very easy to use. It supports the bike very securely, and you do not need to use any straps to secure the motorcycle to the stand. The swingarm stand greatly facilitates chain maintenance, and changing the rear wheel.
The stock Zong is pretty heavy, and the dirt bike stand you bought is pretty narrow. If you decide to keep this stand, I would definitely secure the bike to the stand with straps. However, I would recommend you return the stand you bought, and get a good swingarm stand. I recommend the T-Rex swingarm stand, but you can also get a swingarm stand at Harbor Freight.
http://www.harborfreight.com/motorcy...and-66192.html
Old 05-29-2010, 06:45 PM   #11
i have used it on the zong a few times under the motor and it was wobbly, i don't know if i need to take off the skid plate or not but its not very sturdy
Zongshen Sierra
Old 05-29-2010, 08:08 PM   #12
If you want to keep using that stand, I would remove the skid plate before I lifted the bike on it. However, if you buy a swingarm stand, I think you will much prefer it to the stand you now have. The stand you bought is designed for motorcycles that weigh less than your Zong. I also bought an inexpensive fork lift stand for changing my front tire, and I like it very much. When I get time, I am going to write a review of my fork lift stand.
Old 05-29-2010, 10:26 PM   #13
TheRealWorld   TheRealWorld is offline
Is there a good reason for that skid plate? I leave mine off, it is in the way.
Old 05-29-2010, 10:30 PM   #14
If you ride offroad, even a plastic skid plate will afford some protection for your engine. If you ride in rough terrain, a metal skid plate offers much better protection than a plastic skid plate.
