Old 06-10-2010, 11:36 PM   #1
HotelRed   HotelRed is offline
Check throttle
When I took the throttle apart to install new handle bar I found this:
The left one is OEM. It was close to breaking when I found it. You could probably peal pack the grip a little to inspect.
John
Old 06-10-2010, 11:57 PM   #2
Thank you for the warning, Red!
Old 06-11-2010, 08:16 AM   #3
frostbite   frostbite is offline
I wonder if the wear is cheap construction or simply lack of lube? I know my Lifan was practically dry from the factory.
Frostbite
"The beatings will continue until moral improves"
Old 06-11-2010, 09:27 AM   #4
Both, I think. It was dry but it is also very thin. The new one is not in there perfect as the return stop is different & leaves too much cable exposed so I still have a little work to do.
Old 06-11-2010, 09:43 AM   #5
Dragon   Dragon is offline
I don't think you're suppose to use lube there. Something about attracting dirt.
Chinabikeless
Old 06-11-2010, 01:03 PM   #6
I always use lube under the throttle tube and around the housing that the tube rotates in. I use Maxima Chain Wax because it works, and because I'm using it on the cable as well.
Old 06-11-2010, 03:04 PM   #7
davidsonsgccc   davidsonsgccc is offline
graphite works pretty god in throttle cables and assemblies as well.
my help may not be the best but it is free+-Seek ye first the kingdom of GOD
Old 06-12-2010, 12:27 AM   #8
AZ200cc   AZ200cc is offline
It looks thin to start with, I always add some lube to the tube 8O Not dirty I swear........ Looks like yOu got a honda part to replace it with.
