Old 07-13-2010, 03:00 PM   #1
stonehaven   stonehaven is offline
Gio 110 Chain
Having problems keeping the chain on, keeps getting lose and coming off. What do I need to do?
Old 07-13-2010, 03:05 PM   #2
I'm not a Chinese ATV owner but worn or defective swingarm bushings are a common source of chain issues in this breed.
It could also be a crappy chain and/or sprockets.
Old 07-13-2010, 03:49 PM   #3
Originally Posted by FastDoc
I'm not a Chinese ATV owner but work or defective swingarm bushings are a common source of chain issues in this breed.
I should have mentioned that, I already replaced the bushings.
Old 07-13-2010, 05:01 PM   #4
rotax583   rotax583 is offline
make sure your sprockets are in line,if you tighten one side too much it will make it come off.I just replaced my bushings with some that I made out of teflon.I have no more chain issues..make sure the bolts that hold the swing arm to the axle carrier are tight also.
Old 07-21-2010, 12:19 PM   #5
alignment
you have to make sure the rear axles are straight.... measure from the front to the rear ( from rim to rim) and do that to both sides.. they have to be the same( within 1/4 ) otherwise the chain does not run straight.. I do this on all my atvs that I sell.. many are not straight
Old 07-23-2010, 10:42 PM   #6
Brainsquishy   Brainsquishy is offline
If you put the rear sprocket on the wrong way, it won't line up right. I did that the first time I changed the bushings on my sons Mini Hummer 110cc. I caught it after I looked directly at the alignment of the sprockets and chain. Turned the rear sprocket around and all was good. Hope this helps.
Now if I could just ride and stop working!
Riding a blue plated HSUN 200GY (Otherwise know as a ULIKE 200GY, SUNL 200GY or a VIVA SX200S), a 2010 Gio Mini Hummer 110cc ATV, 2010 Gio T3 Rebel ATV, and a 2002 Kawasaki KLR650, 70cc Katera dirtbike, and a 49cc GIO dirtbike...so far!
