Old 11-25-2010, 02:37 PM   #1
nitro_civic   nitro_civic is offline
help installing front wheel gio 125
just got my gio 125 and have the bike completely done exept for the front tire. They provided me with what seems to be two spacers that you install inside the hub. My problem is I can't seem to install the one spacer (longer and thiker). Has anyone had this issue.
Old 11-25-2010, 04:12 PM   #2
Reveeen   Reveeen is offline
It has been a while.......
The two spacers are to be installed on your axle so that the wheel assembly is centered in the forks. I would think the shorter one goes on the brake side, longer one on the hub side, but I could be wrong, and it goes the other way. You can easily see if the wheel isn't centered (and the brake rotor is in the wrong spot).
[/i]
Old 11-25-2010, 08:43 PM   #3
waynev   waynev is offline
On mine it was short spacer on the left side and long spacer on the right side, and my "sides" are when sitting on the bike, not looking from the front of it.
