Old 02-19-2011, 09:25 PM   #1
JTCAndrew   JTCAndrew is offline
Qlink XF200 SM Front Sprocket Change over
Ok here is a Picture of my 2009 Qlink XF200 Front Sprocket 15T - It is the one I just took off.
The NEW 16T Sprocket I put on was ordered from http://www.jetsrus.com Part #550-16T - I believe they list it as a Suzuki DR-125 Sprocket. The Sprocket was an Exact fit, with Not Problems.
The Socket to remove the Sprocket NUT is a 28mm - I Found somewhere in the forums it was listed as a 24mm - That is InCorrect. You are also going to want to use an Air Impact to get it off as well. It was super tight - The impact made the job so much easier!
Just thought I'd put a few more notes out here about changing the sprocket over in Hopes that it helps someone.
Ride Safe!
Andrew 8) Jamestown, PA
Old 02-21-2011, 12:11 AM   #2
Thank you taking the time to post the good tips for QLink owners!
Old 04-19-2011, 01:23 PM   #3
dmmcd   dmmcd is offline
Does anybody know the JT sprocket cross reference for the 16T? From what I can find, the JTF409-16 is what is listed to fit the 86-88 DR125, which is the same application for the Sprocket Specialist 550-16.
eBay has a bunch of JT sprockets for like $10, or BikeBandit for $13. I was just wondering if anyone had confirmation of this. I tried searching, and nothing came up for the XF.
Here is the drawing:
2008 Yamaha WR250x 2006 Honda CRF250R Sold: 2002 Suzuki SV650S, 2009 Qlink XF200
Old 04-19-2011, 03:13 PM   #4
Dan -
That won't work! Been there done that! Go to www.jetsrus.com and order the sprocket! They have them The part number is:
Sprocket Specialist front sprocket 16 tooth (SKU 550-16) $21.83
Search Sprockets then Suzuki DR 125......
Andrew
Andrew - Jamestown, PA 16134
YouTube Videos:
http://www.youtube.com/user/Jtcomp2009#p/u
2009 Qlink XF200 Supermoto
1982 Honda CM200 Bobber - SOLD
2003 JEEP Liberty SPORT = 3" Lift
2002 Chevy Trailblazer LTZ - Family Cruiser
Old 04-19-2011, 05:09 PM   #5
Okay, thanks. I did read that the extra width around the center is too much and needs to be machined off. Just curious that they are both sold for the same application.
Old 04-19-2011, 05:20 PM   #6
For what it's worth - 2LZ got one not long ago and it was back ordered but he got it.....These are direct bolt on. Mine was super tight had to air Impact it off! 28mm - That was the hard part. Other then that EasyPeezy.
When I did Order mine awhile back they were having website issues, but I e-mailed them (Mike) e-mailed me right back right away and was very helpful. Great Customer Service I think.....Would buy from Again.....
YouTube Videos:
Old 04-20-2011, 10:36 AM   #7
Yup, no qualms with jetsrus, at all.
Their supplier, Sprocket Specialists, did accidently let it slip through the cracks temporarily but got right on it and I got it quick after that. The sprocket all but jumped right on.
I ended up ordering the 44T sprocket for the rear from Mike....and it only comes in the 'more expensive aluminimum version'. That's fine. I think that's what I'm taking off anyway. He did say, "Expect 2 weeks. They need to make it." Fresh sprocket! Straight out of the oven!
I can't wait to try the 16/44 combo on the road. It should really give it some commuting legs.
