04-23-2011, 03:56 AM | #1 |
It's always the carb...unless it's something else. XF200
So, my XF200 was running crappy after getting it out of winter storage. Even though I treated the gas and ran it long enough to get it circulated well, I drained it and replaced with new. Ran a little better but wouldn't idle well, surging. I thought that I might have gotten something in the carb so I pulled the jet and made sure it was clear. Looked good. Buttoned everything back up but same problem. So, thinks I, vacuum leak. I had two plugs on the carb from when I removed the air injection stuff so I replaced them.
Nope, still no love. While the bike was running, I pushed on the plugs to make sure they were seated well. The idle changed when I pushed on the top plug. Mmmm...something is becoming clearer. I could vary the idle moving the carb up and down so I grabbed a can of WD40 (I didn't have a propane cylinder or starter fluid) and sprayed around the intake manifold. Yep, the idle changed. Eureka! I have a manifold leak! So, I took the carb and manifold off. Yep, the top of the manifold had a split in it. I didn't get a picture of it so I borrowed a picture from Andrew's jet change post to show the location (I hope you don't mind, Andrew). I used JB weld to fill it in and clamped it until dry. I will install it tomorrow but am confident that my idle problems will disappear. I have not heard of this happening on Qlink/Qingqi bikes but have read about other makes. Maybe I was too agressive when I changed the jets and did it then. Or it could be another cost cutting measure we have to deal with. I did notice that the screws holding the manifold on did not have any thread lock on them. They do have lock washers, however. They were not on super tight, either. I am replacing them with bolts, however, so that I can torque them correctly. I also put a thin bead of sealer in the manifold O-ring groove to raise the seat up a bit. So, I guess that I would recommend that your manifold screws be checked and tighted (along with all the rest) and maybe even replaced with bolts. |
04-23-2011, 11:52 AM | #2 |
Good diagnosis and repair. I never had an issue with the boots, but I never touched the carb on a Q. It is possible the Q boot is not as good as the S boot. I'd be inclined to but an S boot and upgrade. Or at least try to find a DR200SE somewhere and look at the boot and see if it's made of better material.
Happy to serve. |
04-23-2011, 12:28 PM | #3 |
I can certainly see the benefit to some hex head bolts. You can then snug them up with a box end (likely 8 or 10mm) wrench.
04-23-2011, 08:32 PM | #4 |
How old is your "q" dave? When you store it is it cold storage? Inside? Just trying to get a feel of your storage enviroment. This is something for all "q" Owners to keep in the back of thier minds. Thanks for sharing.
PS - Glad my Picture came in handy!
Andrew - Jamestown, PA 16134 YouTube Videos: http://www.youtube.com/user/Jtcomp2009#p/u 2009 Qlink XF200 Supermoto 1982 Honda CM200 Bobber - SOLD 2003 JEEP Liberty SPORT = 3" Lift 2002 Chevy Trailblazer LTZ - Family Cruiser |
04-24-2011, 12:06 AM | #5 |
Good to know. I have a raised eyebrow to ALL CB rubber..... I'm hoping the Q's are not as dreadful as the Hondanoids I've had or worked on.
My father-in-laws little Hensim 110 quad's rubber boot from the carb to the air cleaner was so hard and dry (3 years old), I could barely saw through it with a hacksaw to remove it! 8O There was NO WAY it would stretch enough to take off without destroying it. Mr. Uni cured the problem. 8)
04-24-2011, 01:06 AM | #6 |
Andrew, my bike is an 09.
Here's an update; the JB weld didn't hold. Well, it did long enough for me to get stranded when the bike shut down. I had to call the wife to come and get me with the trailer. I've been searching on line for awhile and I think I found something affordable; http://cgi.ebay.com/ebaymotors/NEW-R...Q5fAccessories Kind of tired right now so I'll send an email tomorrow and give them the dimensions I need. The DR200 intake won't fit as the carb is larger (31mm) and the GN125 is smaller (26mm). The Kawasaki 125 Eliminator is just right at 28mm but the intake has a fitting that my bike doesn't have. I will post when I find out more. |
04-24-2011, 01:17 AM | #7 |
David,
Q Link has the OEM item on the website right here. http://store.qlinkmotor.com/products...1704.0.0?pp=8& Also, don't forget you have a WARANTEE! Call the Q people and have them send you the item!
Happy to serve. |
04-24-2011, 01:34 AM | #8 |
Thanks Doc. I was going to look there next but forgot. My Warrantee expired in March (Murphy's law) so I can't go that way. My dealer may honor it if I called him but he's 45 miles away. The cost of gas to haul the bike there and back would be more than if I ordered the part and replaced it myself.
The above link to the Ebay site looks more promising then the Qlink part, however. If it pans out, I would be getting a Mikuni part made in Japan. I already know that the part on my bike isn't... |
05-07-2011, 03:55 PM | #9 |
Time for an update. I ended up ordering the intake from Qlink. It ran me about $40 with shipping. I looked and looked and couldn't find one that was a direct bolt on. The 28mm intakes I found had the wrong bolt pattern. I also ordered and received a genuine Mikuni intake from JC Whitney to try if I needed to. The was about half the price. It has a built in O ring while the Qlink one is separate. The bolt pattern is off by 5mm (2.5mm per side) so I feel confidant that I can elongate the holes a bit to get it to fit if needed.
