Old 08-09-2011, 04:50 PM   #1
mark123   mark123 is offline
gio 50 no fire when hot
I have a 50 cc Giovanni atv which has a copy of the old honda 50cc engine. It works perfect for about 20 min. and then it quits and there is no fire at the plug. If I leave it for approx. 1/2 hour it will start up again and work fine for another 20-30 min. Is there some overheat protection system built into these or what could be the problem. Sometimes it works fine for longer periods but this has been happening for over a year now. I tried a new plug and the same thing happens. I have it geared down with larger rear sprocket and smaller front one but also have the throttle limited to approx. half of normal travel. Thanks for any help.
Old 08-09-2011, 05:51 PM   #2
katoranger's Avatar
Really not much to the ignition system. My guess would be a CDI box or the coil itself. Both of these are cheap and easy to get.
Coils will give those symptoms.
Old 08-14-2011, 08:38 PM   #3
TurboT   TurboT is offline
Yup, CDi, Coil, Wire, Plug.
All relatively cheap and easy to change. As Kato mentioned, I'd start with the CDI.
Old 08-22-2011, 12:31 AM   #4
no spark
I would say you coil is getting hot and crapping out when hot.... when it does this... coil it down with water or blow cool air from a compress on the coil... and it this helps ,... then you know it is the coil... or just change the coil... and see .. tehy are cheap
ABIBABA ATV ETC
