Old 05-13-2007, 10:49 PM   #1
mdionis   mdionis is offline
Finally but still have one question....
Well as some of you may know I had major problems when I purchased my Roketa DB-07A (RSX-200E) First started with a faulty motor then xxx-motorsports sent me a replacement motor only to find that the new motor didn't have the chain driven camshaft. Needless to say I also noticed that the motor wiring on this replacement didn't match up to my Roketa harness. So I still tried my best with that motor and never had any luck So finally after saving up my money and having the approval of the wife I purchased a new motor on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...1145563&rd=1,1
I finally have my bike up and running!!! However the front sprocket is a 14T but doesn't work with my chain. My rear sprocket measures 1/2 inch tooth to tooth, I think it is 56T but my front sprocket measures 5/8 inch on this new motor. So I assume that I need to get the 14T for a 428 chain, which would then make it stock?
Thanks,
Mike
Old 05-13-2007, 10:57 PM   #2
msRandi   msRandi is offline
Send a message via AIM to msRandi
Are you going to be useing the bike on the street? if you are I would reamend going to a 17 tooth front.
Love from the Arizona High Desert
Old 05-13-2007, 11:02 PM   #3
Guest
Posts: n/a
Correct, the Lifan Engine with the OHC comes with a 520 sprocket, you need to change it to a 428.
Old 05-13-2007, 11:05 PM   #4
Know any good place to get a 17T 428 front? Will I need to do anything to the chain?
Old 05-14-2007, 06:03 AM   #5
What did you do with your sprocket off the original engine?
I just put one of those engines in mine and it most diffenently is a #520 size sprocket on there.I just swaped my old sprocket onto the new engine, done.
Old 05-14-2007, 06:59 AM   #6
ob1   ob1 is offline
Whatcha gonna do with the spare motors?
Old 05-14-2007, 09:45 AM   #7
My original motor was shipped back to XXX-Motorsports. The replacement motor that they sent back has a 12T front sprocket but doesn't work either. So I have 2 Sprockets that do me no good.
Mike
Old 05-14-2007, 09:47 AM   #8
I only have one spare as XXX-Motorsports required me to send the original faulty motor back to them before they sent the replacement.
I have listed this spare motor in the For Sale forum. I am including the intake manifold, and original carb with the spare motor.
Mike
Old 05-15-2007, 09:28 AM   #9
So I purchased a 17t 428 front sprocket from ebay. I have a 56t rear. Will I run into problems with my chain being short? I checked my rear axle and I barely have anything left to move it forward.
Old 05-15-2007, 10:49 AM   #10
red2003   red2003 is online now
I think it WILL be too short. You can always go to the local bike shop and pick up a few 428 links and another master link and lengthen it. Not a big deal. After a short while it'll stretch to fit anyway.
