Valve Clearance Check #2 and #3
The first check for valve tappet clearances was at 850 miles:
http://www.chinariders.net/showthread.php?t=15650 The valve clearances were at the same .003" (3 thousandths inch) as CSC had set them during their "set up". So that's where I left them. 2,650 miles later, at 3,500 miles, I checked the clearances once more. ![]() ![]() This time was different: Intakes: .005" Exhaust: .001" My first thought was the piston was at top dead center on the wrong stroke. So I checked: ![]() ![]() Looked to be in the correct position. Readjusted the clearances to .003" as recommended by CSC. ![]() Put the bike back together, and ran the engine at idle for a while. All seemed fine, except for the tapping noise. I had been noticing a tapping noise from the engine recently, which was becoming louder. After a couple of emails to CSC, it was suggested that I recheck the valve clearances. So for the second time in 3 days, the bike comes back apart.... ![]() The valve clearances were right where I had left them, .003" ....and the .004" would not fit. ![]() ![]() You all know how much fun checking the valve clearances is .... ![]() More to follow. Hopefully with some favorable news. Oh, and BTW when you have a chance, check the battery terminals on your RX3. There was a significant amount of corrosion on both terminals: ![]() jb
Whoa there Buckaroo. In the picture of the exhaust tappets, there looks to be part of the frame broken. Just to the left (in the pic) of the green head bolt. I'd draw a circle around it but my computer doesn't have breaker points and I'm not savvy on new tech stuff.
Jay has a good eye. The end of that bar should be rounded, with a bolt hole for the lower radiator mount. It looks broken off.
jbfla, can you get a pic of that mount from the side? ![]()
that sure look like it is broke too me good eye jay
Peace and Zong Life
Looks to me that it's not broken... we're seeing the bend with the soldered nut where the radiator bolts just at the right angle.
#6 | |
The radiator is currently bolted to it....pardon me for not wanting to unbolt the radiator......again...for a photo. ![]() jb
When I talked to Gerry about my new engine, he said that he has been recommending a gap between .06 and .08 mm.
#9 | |
As Spud says: Slappy valve is a happy valve. Maybe the factory wanted a quieter valve train. Also as valve train components wear they almost always close up And my biggest fear in extending the valve adjustment intervals is for there to be zero clearance. Just seems like every reason to adjust to the high side of the specified clearance. |
#10 | |
CSC (Gerry) told me that during the setup, the valves are set to .003 inch. He again verified this by email to me, and to another RX3 owner. .003 inch = .0762 mm jb
#11 | |
jbfla :
Great photos !!!! I've checked the website here but cant find an in-depth video of a valve check... I was kind of surprised. I'm ordering at the end of the month and can't wait. I jump between the orange, new gray and white like a bobblehead.....I was originally settled on the blue ... oh well ! |
#13 | |
