Old 04-18-2016, 09:59 AM   #16
CSaddict   CSaddict is offline
CSaddict's Avatar
It didn't come with any shims. Keep in mind, I did not get this bulb from CSC but it appears to be the same manufacturer and style. I actually just came in from modifying it. I cut off the light deflectors on each side and orientated it so the LEDs face up and down instead of side to side. Obviously I am destroying the bulb but for experiment sake I don't care. I also have another brand new bulb as it was pack of 2.
This is the bulb.
Original install is in my blog here: https://www.facebook.com/My-CSC-Zong...0302595973417/
2016 CSC RX3 Ginger Edition
Check out my blog here:
Old 04-18-2016, 10:04 AM   #17
RedHawk47   RedHawk47 is offline
RedHawk47's Avatar
I tried one LED headlight and found that it had a "black" spot in the center of the low beam, and low beam cutoff was poor to say the least.
I have found these bulbs which claim good low beam cutoff plus the typical LED specs. I have not tried them yet; they are not cheap; $250 for a pair.
Available here, and other places:
http://www.xenondepot.com/h4-philips.../12953bwx2.htm
Philips' info: http://download.p4c.philips.com/file..._pss_engau.pdf
From this info sheet:
Philips patented SafeBeam optical design brings maximum visibility with a beam pattern that does not glare other road users. Similar or better beam pattern than standard halogen lamp, ECE beam pattern compliant*.
* There is no ECE regulation existing for LED bulbs. ECE beam pattern compliance is tested on several commonly used luminaires where the LED bulb beam pattern matches the ECE approved halogen beam pattern
Dan
CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650
Old 04-18-2016, 10:09 AM   #18
CSaddict's Avatar
I will not spend anywhere near that on a light. I rarely ride at night. I will switch to a standard 9003 Silverstar Ultra if my modification doesn't work.
Old 04-18-2016, 12:24 PM   #19
rtking   rtking is offline
I used the Silverstar and while the light output is good, the heat caused some bubbling of the reflector at the top.
I switched to the LED bulb that Detours is using and find that the light pattern is pretty good. I added spot LED aux. lights to project further down the road and I'm actually really happy with that setup.
Old 04-18-2016, 01:24 PM   #20
keithmaine   keithmaine is offline
keithmaine's Avatar
Which led do you & Detours have in now, I know he has tried a few.
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp,
Old 04-18-2016, 03:21 PM   #21
linuxyeti   linuxyeti is offline
Hi All
Thanks for all the suggestions, I've got some 55/60W 5000K bulbs, but I may hold off installing them, and see if anybody comes up with better LED bulbs.
Cheers
Tony
Old 04-18-2016, 08:55 PM   #22
detours   detours is offline
detours's Avatar
I'm using a 3200 lumen CREE lamp that I found on ebay, like this one. The link may not last long, but you can search for '36w 3200lm H4 CREE MT G2 LED Headlight'
You can read my review with pics here. It's a nice bright light that shines with a big round pattern with no shadows. It throws a lot of light to the sides and except for the lack of a flat cutoff, it's very nice.
I aimed it kind of low and I'm still using it, but I don't like blinding other drivers, so I'm still hunting for a strong LED lamp with a good cutoff.
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 04-19-2016, 06:34 AM   #23
keithmaine's Avatar
Thanks for the info Detours.
Old 04-20-2016, 08:17 PM   #24
kohburn   kohburn is offline
kohburn's Avatar
some additional LED driving lights is probably the best way to go.
-whatever you do, just be awesome.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 04-20-2016, 10:23 PM   #25
detours's Avatar
Here's my latest LED find. It looks very promising and not too expensive at $60/pair (w/ free shipping). The 'H4 9003' size fits our reflector.
http://www.ebay.com/itm/162016496792
  • It was designed to emulate a halogen lamp's overall dimensions, including filament length, orientation and placement.
  • It claims 25W per lamp.
  • It has a front shield to prevent direct glare.
  • It has a low beam shield to create a cutoff line.
  • The lamp can be rotated in 90 degree increments to match your reflector design.
  • It uses a fanless heatsink.
  • The heatsink is removable and reversible for tight applications.
I haven't found the overall dimensions yet, so I'm going to keep looking before I purchase.
Red 5 standing by!
2014 Ural Patrol
Old 04-21-2016, 12:26 AM   #26
Nice find, Detours! I like that it has a sharp cut-off, but would like to see it perform in a YouTube video or in person before purchasing. The other 3200LM LED headlight you wrote about convinced me to try that one also, and I've been quite pleased with it. But if this really provides greater lighting (evenly spread out in front of the bike), I may be inclined to buy one myself!
Old 04-21-2016, 12:40 AM   #27
Jay In Milpitas's Avatar
RT, their page has a video link showing the adjustment to tune the LED to the reflector.
I like it, Joel. While watching the video and how they're tuning it, I started pondering how to link the heat sink to a windshield wiper unit to give the effect of a MARS light like on locomotives.
Must be time for my meds again.
Old 04-21-2016, 02:28 AM   #28
detours's Avatar
Here's a link to a YouTube demo of the LED. They even power it up in a jeep headlight. Really impressive.
Red 5 standing by!
2014 Ural Patrol
Old 04-21-2016, 06:03 AM   #29
Hi Detours
They look like really good lights, could you keep us informed on how you find them, if you do end up getting a pair.
Thankyou
Tony
Old 04-21-2016, 07:24 AM   #30
Here is the embedded video.
