08-07-2019, 09:40 AM | #46 |
You can try doing a ECU reset. On most EFI systems it's just a matter of turning the key on and off 5 times within a few seconds.
08-08-2019, 12:39 PM | #48 |
EFI has its place, just not on a small, low performance unit, IMHO. It's not like little motorcycle carbs are very complex. Even our little non-pumper carbs have excellent throttle response. I haven't had any real issues with any of my motorcycle carbs that weren't easily cured. Maybe the EFI is for future EPA regs possibly?
08-08-2019, 05:47 PM | #49 |
Isn't it the same thing as ecotronics?
Just download the programmer and see if it connects and knows the eco. Then you'll have to learn how to program it. Iv'e downloaded a copy a while back and it seems very simple, compared to megasquirt/megatune. https://www.ecotrons.com/small_engin...injection_kit/ You can use the exact same troubleshooting method that one would use for a car. The ecu is likely fine but not speaking to one of the sensors.
500cc Hawk Project http://www.chinariders.net/showthrea...372#post281372 |
08-09-2019, 07:27 AM | #50 |
Quick update. I have intentionally done nothing to the bike except ride it. I am still just under 150 miles, but I must say it has gotten way better. I still think the idle is a little low, but it is now running much better(and not stalling) at low RPMs.
08-09-2019, 07:47 AM | #51 |
This is good news maybe the computer just needed some time to adjust
08-10-2019, 12:23 PM | #54 | |
08-13-2019, 07:59 AM | #55 |
I'm all registered and legal in SC, wasn't TOO much of a hassle. Took it for one ride, tried to do some 50mph cruising. It is not smooth when cruising. Don't really know how to describe it other than it is just a little "jerky." It certainly is not terrible, but it is irritating. I will give it more time before I start fiddling.
08-13-2019, 10:12 AM | #56 | |
Like I suggested in the beginning, try resetting the ECU by turning the ignition switch on and off 5 times within a few seconds. If that doesn't reset it then call American Lifan again and they may tell you how to reset it. Resetting the ECU will usually resolve most issues.
08-13-2019, 10:55 AM | #57 | |
I have not tried this yet, but I am going to. |
08-19-2019, 04:10 PM | #58 |
I am ready to hear other's reports on this bike. Certainly someone is close, eh?
I've tried a hotter plug, higher octane gas, and resetting the ecu. Still runs a little rough. |
08-19-2019, 05:44 PM | #59 |
I'll let you know by the end of the week. Mine is suposed to be deliverd tomarow. How many miles you got on yours.
08-20-2019, 07:57 AM | #60 |
How many miles you got on yours.[/QUOTE]
Only 240. |
