Old 09-11-2016, 12:56 PM   #16
StevieUT   StevieUT is offline
StevieUT's Avatar
Yeah, I'd say that's a drawback. I'll stick with the 17" rear but with a warp9 rim. I really want to install a rim lock and there's nada for the stock rear rim. I do think I will go at least with 19" in the front, which should help with the silt I run into. Also, I'm not crazy about the lack of availability of heavy duty tubes for the 18" front.
Thanks for the replies!
Old 09-11-2016, 12:59 PM   #17
Thumbs Up
Wow surf, you were not intended to get such use and abuse from a $3800 motorcycle. Cease and desist immediately and go purchase a $15k bmw.
Old 09-11-2016, 05:50 PM   #18
GSC   GSC is offline
Originally Posted by willy dog View Post
the 17inc. rear can bottom out and scrape the inside of the fender and air box would be careful adding to rear tire
Especially with the ' lowering link ' installed.
I must add that Ryan warned me first ! I went for it anyway, and yes a few hard knocks and the Kenda big blocks scrape the air box connectors.
Old 09-12-2016, 01:21 AM   #19
detours   detours is offline
detours's Avatar
Let's nail down the rear wheel/tire/suspension combinations can rub the inner fender and airbox.
Sounds like these combos will rub:
  • 18" rear wheel and tire with stock dogbone
  • 17" rear with off-road tire and lowering link
Any others?
I haven't seen any rubbing with my stock 17" wheel with Shinko 804/805 (130/80-17) using either the stock or progressive shock, and I've ridden some pretty rough trails.
Red 5 standing by!
2014 Ural Patrol
Old 09-12-2016, 07:12 AM   #20
Juanro   Juanro is offline
Juanro's Avatar
With a 17 rim and a 120/90/17 Metzeler Tourance, standard dog bone link, it rubs. I had to add a monoshock extender to raise it a few centimeters.
Old 09-12-2016, 11:46 PM   #21
3banger   3banger is offline
3banger's Avatar
I've up graded to the 19" mostly because I made a poor on line choice on a rocky step up and made the OEM 18" wheel a little more square. But IMO the upgrade is worth it have better tire choices. My new favorite is the Heidenau K60 Scout front (110/8019 59T) and rear (130/8017 65T). They are just as good as the Kenda's off road but corner like a street tire on the pavement. The Kenda's get a little squirrly when you push them on asphalt.
Old 09-13-2016, 07:25 AM   #22
willy dog   willy dog is offline
willy dog's Avatar
Any others?
i weigh around 280 with no trouble on the kenda's 5.10/17
Peace and Zong Life
Old 09-13-2016, 08:00 AM   #23
madsocial   madsocial is offline
madsocial's Avatar
I actually got the 19 inch as a spare wheel. I even bought a spare 17 inch wheel for the rear. That way I can quickly change from off-road to on-road tires without having to deal with tire irons and all that mess. For the cost it just made sense. Also, the front 19 inch will offer you more off-road tire options than the stock 18.
Cheers!
Rania aka madsocial
2016 Zongshen RX3 (CSC Cyclone)
Pay it Forward!
Old 09-13-2016, 01:29 PM   #24
jbfla   jbfla is offline
Just finished mounting a Shinko 705 (110/80-19) on the 19" rim ----- twice
I had it mounted, then looking over on the work bench, I realized I had forgotten to put on the rimstrip.
Adding to the fun, I couldn't use my wheel mounting stand because the centering spindle was too large to fit through the wheel bearing.
I don't know if it makes a lot of difference, the 19" rim is 2.15" and the Shinko tire calls for a 2.50" rim.
The tire seems to fit OK.
jb
2014 XT 250........
Old 09-14-2016, 07:02 AM   #25
jezzrite   jezzrite is offline
Send a message via Skype™ to jezzrite
What spoke length did you use for this? Can one use the original 18" spokes?
I asked this because the stock 15" spoke fitted nicely with my new 17" rim for the rear tyre (South East Asia got 15" wheel for stock), and I wonder if the front can do the same.
jb
People sit on an exploding, volatile, fast-moving two-wheeled killer machine, and call it "enjoying the moment".
No wonder aliens never make contact with us.
-A Zong rider-
Old 09-14-2016, 11:54 AM   #26
The 19" wheel was purchased complete with hub, spokes, and rim from CSC, the US distributor.
jb
2014 XT 250........
Old 09-25-2016, 08:58 PM   #27
I can confirm with 100% accuracy that if one wishes to change from 15" rear to 17" and 18" front to 19", one does not need to buy new spokes for both rear and front. The original spokes are of sufficient lengths.
These are the proof. My Zong is outfitted with rear Mitas E07 130/80-R17 on a 2.5x17 rim with stock spokes and front Mitas E07 110/80-R19 on a 1.85x19 rim also with stock spokes.
Can't wait to try them out!
Rear Mitas E07 130/80-R17 on 2.5x17 aluminium rim.
Front Mitas E07 110/80-R19 on 1.85x19 aluminium rim. Note the clearance between mudguard and tyre. Entirely stock.
Note that after changing to 17 rear and 19 front, the double stand is unable to give ground clearance to both wheels. Only managed to keep the bike stable.
-A Zong rider-
Old 09-25-2016, 09:05 PM   #28
Jay In Milpitas's Avatar
Very good, Jezzrite!
The stand can be changed to hold one wheel off the ground with just a little metal welded on. Very easy.
Old 09-26-2016, 01:08 AM   #29
Nice. I will do exactly that. Thanks Jay!
-A Zong rider-
Old 09-26-2016, 01:21 AM   #30
Pure awesomenes! I am looking foward to mounting my new tires too.
