Old 05-03-2015, 11:12 AM   #3301
Mudflap   Mudflap is offline
When the master cylinder sight glass started leaking on my Lifan I glued a dime over it with JB Weld. That was 4 years ago and it's working fine. Now my bike is worth 10 cents more.
Old 05-03-2015, 12:10 PM   #3302
Veteran   Veteran is offline
Veteran's Avatar
Awesome
That's some good stuff!
If I did that, my MAK would be worth approx. 36 cents total (US money).
That JB weld is really under-rated in my opinion. I don't slaver it on everything, but it has kept me riding while awaiting a more esthetically pleasing repair.
Old 05-03-2015, 02:39 PM   #3303
katflap   katflap is offline
katflap's Avatar
That's a cool jack. I considered making an adapter for my car jack, so I can lift my bikes in a similar fashion.
Yeah, I guess if you have the right gear it wouldn't be too difficult to make an adapter.
Certainly an interesting project
Old 05-03-2015, 02:44 PM   #3304
katflap's Avatar
That is a true China Rider solution. Does the bicycle speedometer have a backlight for viewing at night?
Unfortunately not , I guess I could always have a small clip-on LED light to illuminate it
Though I don't do a lot of night riding
Old 05-03-2015, 02:52 PM   #3305
katflap's Avatar
You are wise to keep the spokes tight. I always examine the entire wheel whenever I change a tire. I also tightened a few spokes on both wheels when I recently changed both tires. You procedure was good, and you wheels should be in fine shape.
After you install the wheel, give it a spin to check for any wobble. When the wheel begins to wobble noticeably, it's time to true the wheel.
Thanks Spud , I'm glad of the reassurance.
Yes, these tires handle very well on pavement, even while riding full throttle on limited access highways.
That's good to know , will probably go for some when my stock tyres wear out. might have to import coz of my Pesky 15 inch wheel
Old 05-03-2015, 03:07 PM   #3306
Originally Posted by G19Tony View Post
The OEM battery is 11AH. I've been using the BatteryMinder brand maintainers for years, with never a problem.
What is the rated output of your BatteryMinder?
Old 05-03-2015, 03:08 PM   #3307
Originally Posted by Veteran View Post
I spent 30 minutes carefully crafting a note about these master cylinders and when I went to send it, my internet disconnected and I lost it. So now I'm pissed off....
I feel your pain. That's why I highlight all of the text and copy it to the clipboard, before I hit send. If the connection fails, at least all I have to do is hit paste.
Old 05-03-2015, 03:28 PM   #3308
katflap's Avatar
Unused Connectors
I've been having a bit of a poke around these spare connectors and matching them up to the circuit diagram.
On my RX3 there's one under the tank and 2 under the pillion seat area.
My best guess is
under the tank
Red 2 pin connector - to a solenoid valve to shut off the fuel supply.
White 3 pin connector - "tip over" switch to operate the shut off valve for
when you ditch your bike.
For some reason they decided not to bother.
White 2 pin connector - No idea, but I know some bikes will have a connector like this for connecting a switch to turn on the MIL light so it will flash diagnostic codes.
yeah ,you know I was tempted to short the pins but I didn't want to risk frying the ECU
Or maybe a side stand kill switch as the Delphi MT05 has it listed
Old 05-03-2015, 04:47 PM   #3309
Originally Posted by jezzrite View Post
A few days back I rode through a biblical, tropical, torrential downpour (visibility is about 100-200 meters) for about 50km.
Yeah, not really smart, but I was too lazy to stop, and if I did, I will have to ride a very lonely pass stretching about 30km in the dark, and it gets very spooky there (there have been cases of supernatural stuff there, and I'm not too fond of experiencing it first hand) .
Anyhow, after 20km or so in the rain, the gear indicator disappeared from the display, while others showed what they were supposed to show. I was at 5th gear at that time.
However, when I dropped to 4th gear, or upped it to 6th, the number reappeared. It was just the number 5 that vanished.
After a while, the number displayed normally, as though nothing happened at all.
Waters messing up with electronics? Why only gear indicator was affected?
I would surmise the temporary problem was caused by the torrential downpour. If the problem has disappeared, all is probably well.
Old 05-03-2015, 04:48 PM   #3310
My best guess is
under the tank
As always, thanks for sharing your research, Kat.
Old 05-03-2015, 05:17 PM   #3311
oldqwerty   oldqwerty is offline
Unless it reappears the next time it rains, or you ride through water, or a dog pees on the bike. Yes, pee happens. I think the Chinese have the right mindset about dogs. Yum!
"Thou shall not Zong" is not a commandment.
Old 05-03-2015, 06:47 PM   #3312
Miqueas   Miqueas is offline
Do you think the heat I'm getting from the right side is because of this hole?
I've notice the "patch", Zongshen put it there is not convering the holes.
what do you think? I have checked other RX3 on the web and they cover the holes.
Now... the metal thing there, is just to patch, I guess there's not other funtion.
3 holes.
Old 05-03-2015, 07:30 PM   #3313
detours   detours is offline
detours's Avatar
Maybe it's water-related, but some gear indicators require a really solid shift to activate. On my v-strom sometimes I'll be in gear but the indicator reads a dash. Happened more during break-in but less as I put on miles and started making more solid shifts.
Red 5 standing by!
2014 Ural Patrol
Old 05-03-2015, 09:46 PM   #3314
3 holes.
Is hot coming out of the holes when the bike is running? If so, that could be the problem.
Old 05-03-2015, 10:18 PM   #3315
I was hoping for some ride reports at the end of the weekend.
