Old 12-07-2014, 05:17 AM   #1
burge   burge is offline
cg200 waterpump gear
Have had cooling problems .fan stopped .engine popping at high rpm .water use . overflow tank venting continuously .radiator leak checked and fixed.new electric fan . removed water pump cover and found that there was no resistance , so pulled side off engine. Nothing major 13 screws clutch cable foot well ,peg and other crap ,got to the guts and found inner gear stripped , so deciding whether to fix this up or just get a new motor , this still runs fine but I am concerned that the heat may cause some issues later on ,plus how and where to find water pump gear cheap enuf
Old 12-07-2014, 06:19 AM   #2
humanbeing's Avatar
http://cqgty.taobao.com/search.htm?o...ce=&highPrice=
Old 12-07-2014, 05:43 PM   #3
Cheers but that site is in Chinese , wondering if I should just put it back together without the pump and see what happens
Old 12-07-2014, 11:57 PM   #4
pete   pete is offline
pete's Avatar
Doh!
will run for at least 20 years with no cooling..
never figgered out why they cool a motor.... just
extra weight..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 12-08-2014, 12:06 AM   #5
I suspect that it'll struggle without the cooling system, since there are no cooling fins on that cylinder. You could certainly convert it to air cooled.
Old 12-08-2014, 11:16 AM   #6
Water pump
You can try CHINAPARTSDEPOT in Vancouver... Check their site on the web for ph#.. he has parts for everything... major parts supplier
ABIBABA ATV ETC
Old 12-08-2014, 04:34 PM   #7
Thanks flash I,all try them , I,m having no luck finding a replacement gear on the net , and there definitely won't be any here in tasmania ,can u just buy a finned cylinder and make it air cooled (piston as well)
Old 12-08-2014, 08:48 PM   #8
humanbeing's Avatar
burge is in Australia. If can't find it locally, buy from China seems the LAST resort. OZ & parts: http://www.chinariders.net/showthread.php?t=10750 btw: taobao.com had official forwarder to OZ if READS chinese (NO agent NEEDed) Y85 (1st kg) + Y26 /.5 kg http://www.taobao.com/go/chn/transit...0.0.0.0.wYcn2v
Old 12-09-2014, 04:28 AM   #9
Cheers HB
