Old 04-28-2015, 08:58 PM   #1
iquitmyscene   iquitmyscene is offline
Zongshen Petcock
So I have a pretty big gas leak from the stock petcock and gas tank. I already used many different things to try and seal it back up without having to buy everything again, it worked great but now it leaks again. Does anyone have any suggestions? And if need be, is there a non-Chinese replacement (so I don't have to wait forever for it) and do i need to order the fuel tank and petcock together? Thank you for all your help.
Old 04-28-2015, 09:41 PM   #2
Adjuster's Avatar
Your petcock is available on Ebay and Amazon. You just need to match up the one you need. If your petcock is the kind that can be disassembled then you only need to replace the o-ring. Post a picture of your bike and the petcock and we can probably help you out.
Do you think there is something wrong with your fuel tank?
Old 04-30-2015, 06:24 PM   #3
I have Zongshen Sierra 200. The motorcycle is currently at my friend's house that lives far away, so I can only send a picture I found online. Below is the petcock that I have, and a picture of the motorcycle I own.
Old 04-30-2015, 09:32 PM   #4
Adjuster's Avatar
That is a very common petcock. But you do need to know the thread size of the nut the red arrow is pointing at as they come in different sizes.
Old 04-30-2015, 09:34 PM   #5
Adjuster's Avatar
I don't know if this is the correct one for you but if it is I would be all over it. It is completely serviceable with removable valve and removable filter and removable drain bowl.
http://www.ebay.com/itm/Fuel-Petcock...d64038&vxp=mtr
Old 05-01-2015, 12:30 AM   #6
I gave my original, Zongshen, ZS200GY-2 fuel tank to Weldangrind. He can measure the fuel petcock to help you ensure you purchase the correct one.
Old 05-01-2015, 09:36 PM   #7
That would be so helpful!! Thanks!
Old 05-03-2015, 09:57 PM   #8
mrpete   mrpete is offline
I had the same problem with my Hisun Viva. Definitely, get it replaced. I also had a struggle finding the right one for mine as well. Since the original one had a reserve bowl on it(it had a crack in it). I wanted a regular one. I measured from screw hole to screw hole and also measured the width of the apparatus itself. Also, I had to compensate for the reserve as well.
check your measurements against this:
http://atvparts.cc/yamaha-op-ct-ct1-...SD&language=en
Old 05-03-2015, 11:41 PM   #9
ripcuda   ripcuda is offline
ripcuda's Avatar
I have a similar petcock on my Runmaster. Thankfully, it doesn't leak.
How does the reserve work on a single pickup tube petcock like that?
Cheers!
'20 TaoTao Hellcat 125 "grommet"
'04 Yamaha TTR-125LE
'00 Yamaha TTR-90
'07 Kinroad XT200GY Runmaster (sold)
'07 KMD GY6 150cc ATV (sold)
'07 Kangchao 250cc ATV Monster (sold)
Baja Moto DB-30 "Doodlebugs"(x3) (sold)
'06 Hi-Bird 200 parts bike (sold)
Old 05-04-2015, 12:44 PM   #10
Adjuster's Avatar
Inside the filter is a 3" straw. On open the gas flows in through the straw and you will run out of gas at the top of the straw. On reserve gas flows in at the bottom of the straw and you will run out of gas when the tank is empty. The height/length of the straw is your reserve amount.
Does this make any sense? Hard to explain.
Old 05-04-2015, 01:05 PM   #11
I finally remembered to measure the petcock. It is 6cm overall, and the thread is 15mm in diameter. Is there another measurement that you need?
Old 05-04-2015, 05:51 PM   #12
Thanks everyone for their help so far... weldandgrind, how do the measurements of the petcock you have match up with
and
http://www.ebay.com/itm/Zongshen-GS2...8e4833&vxp=mtr
Looks like I would also need to know the entire length (with filter on top) also. I think. I'm really bad with these
Old 05-04-2015, 06:12 PM   #13
Adjuster's Avatar
The one from the atv parts store is the wrong kind. The one from Ebay looks correct but again you need to confirm the thread size. They come in all different sizes. The Ebay one is also too expensive. You can get them for $10.00.
Old 05-04-2015, 06:18 PM   #14
Adjuster's Avatar
Going by Welds information if you need a 15mm threaded petcock this should be the correct one.
http://www.ebay.com/itm/ATV-Go-Cart-...c06f15&vxp=mtr
Old 05-04-2015, 09:37 PM   #15
X2. That's a fair price.
