09-11-2018, 09:29 PM | #1 |
Hawk Clutch problem
So yesterday I was riding some trails with some high grass and all of a sudden my rear wheel stopped spinning. Seemed like the clutch wasn’t engaged so I tried to adjust clutch lever and was really tight. So I had to leave the bike over night and walk home, this morning I got my tools headed to my bike and had to release my clutch cable as much as it would go to finally get the clutch engaged and it still feels like it’s not fully engaged. Well I was able to get it home but felt like I was riding the clutch the whole way so I couldn’t get enough speed to get out of second. Bike was running fine before, clutch was adjusted good but now it seems like I need a longer cable to fully engage the clutch. I just took side cover off and inspected clutch I could find nothing wrong. Any ideas on what could have happened, I need y’all help.
09-12-2018, 01:11 AM | #3 |
Wow, how many miles did you get out of your original clutch?
And do y'all use clutch to change gears or not?
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
09-12-2018, 02:52 AM | #4 |
i sometimes dont use the clutch to change gears. its easier gojng up thru the gears than going down but with practice you can go down too.
09-12-2018, 09:32 AM | #5 |
Did you pull the clutch pack from the old spare parts engine?
09-12-2018, 09:34 AM | #6 |
Not sure on how many miles because my speedometers broke but not that many miles. I was a dumbass though and forgot to screw the dipstick in after putting oil in and rode it for about 5 min before I noticed luckily I was right by an auto parts store. Only lost about half a quart so I topped it off and sprayed the bike down with a whole can of degreaser. Oil was everywhere (please don’t judge me) bike ran fine though. Went home inspected bikeveverything looked fine except for the weird smell. I thought might have been oil burn. Took the bike to the car wash and went riding some more. Ended up in some wood trails and I had to ride the clutch a lot to get through the tall grass and mud and that’s where my clutch finally gave. Must have been on verge of warping from no oil. When I inspected them they looked fine, I cleaned them and put back together. Bike still did the same so more research online on how the clutch actually works and symptoms of warped disks. I took it back apart and put in different clutch disks. I could tell right away with how the clutch arm felt compared to the burnt onesthat that was the problem.
09-12-2018, 09:42 AM | #7 |
What sprockets are you running when you trail riding? Too tall a gear ratio can put a load on the clutch. That's why I swap out from a 17 to a 15 on the front for trail and mud.
09-12-2018, 12:06 PM | #8 |
I run a 16/43. Pretty stupid of me to try riding through all that mud and tall grass. Also had the wife on the back. We were trying to get to the beach next to the creek. Never made it and had to walk about an hour home. She wasn’t to happy. Live and learn, won’t make that mistake again
09-12-2018, 12:42 PM | #9 | |
Oh yeah, She won't let you forget , so don't worry about making that mistake again.
