Old 07-16-2015, 09:11 PM   #3886
rjmorel   rjmorel is offline
rjmorel's Avatar
Originally Posted by DanKearney View Post
Did my first oil change the other day.
I had to put at least 6 oz more oil than the manual calls for into the motor in order to get the oil to show at all in the view window.
Anyone experience this? Where's it all going?
Cheers,
Dan K.
Dan, I did the same thing first time around and ended up taking some back out. Now I put in about 1 1/2 qts, then start it for a few minutes make sure filter and drain bolts are not leaking. Then I top it off.
I think it was Spud who said to just add 1.7 qts and it will be right. I believe it does ebb and flow from tranny to engine so in the window it appears to rise and fall making some of us early on think that gas or water was getting in our oil.
This explains the raise and fall from tranny to engine on the blog a few weeks back:
http://californiascooterco.com/blog/?paged=3
rj
Live Zong, and Prosper
Old 07-16-2015, 10:40 PM   #3887
3banger   3banger is offline
3banger's Avatar
I have also learned to pull the slotted oil cap on the clutch cover when adding oil. I think this allows air to escape and allows the two volumes to equalize more quickly. I even have a highly specialized tool for this; they only cost a nickel!
Old 07-16-2015, 11:32 PM   #3888
cimarronEric   cimarronEric is offline
Originally Posted by SpudRider View Post
At Colorado elevations, you will notice a definite improvement in the engine's performance with a 13T C/S sprocket.
Got an extra one you can send me, Spud?
Noooob
CSC RX-3 Cyclone
Old 07-16-2015, 11:47 PM   #3889
Originally Posted by 3banger View Post
Any Imogene photos? Did you make it to the top?
Eric, maybe we can get a CO RX3 group 13t sprocket group order together.
I didn't make it to the top because I couldn't solve this puzzle.
Name:  Imogene Puzzle.jpg
There's just no way to maintain enough momentum.
I watched a DRZ400 go up it.
I'd be in for a group buy if CSC doesn't make it available.
Noooob
CSC RX-3 Cyclone
Old 07-17-2015, 01:59 AM   #3890
Thanks for the info. My wife's working in China right now, I'll have to get her to do a little buying for me. Got a part number or seller's link?
Cheers,
Dan K.
Yes, I placed a link in the post your quoted. Here it is, again.
http://item.taobao.com/item.htm?id=39633060740
I gave Ryan at CSC a good report on the 13T C/S sprocket. I'm sure CSC would like to stock the 13T sprocket, but they can't get them from Zongshen. I'm pretty sure Zongshen doesn't manufacture sprockets; they get them from another manufacturer. CSC merely needs to have Zongshen tell them the name of the manufacturer, and then CSC can stock the 13T sprocket.
Old 07-17-2015, 07:23 AM   #3891
Huck369   Huck369 is offline
Huck369's Avatar
Spud, at what RPM are you running at 65 mph now?
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 07-17-2015, 09:04 AM   #3892
DanKearney   DanKearney is offline
Don't know how I missed that. Thanks for re-posting.
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 07-17-2015, 10:57 AM   #3893
3banger's Avatar
Eric, that certainly looks like a bit of a tricky section. Was there much wheel spinning with the stock tires or more of a just running out of torque at lower engine RPMs? I'm excited and a little worried to give a try my self. I went right up on the XT250 last year but all the snow was gone by Sept.
Old 07-17-2015, 11:03 AM   #3894
Snow was off the road. I'm running 50/50 tires now so it was really just a torque issue.
Noooob
CSC RX-3 Cyclone
Old 07-17-2015, 02:03 PM   #3895
I'm sorry, I only ordered one of them as an experiment. However, I have good news. Ryan from CSC told me they will definitely be stocking the 13T C/S sprocket.
Old 07-17-2015, 02:22 PM   #3896
Cheers,
Dan K.
rj
The engine in my Honda XR650L has a similar design, with a 2-chamber oil pump. Basically, you need to measure the oil when the engine is at operating temperatures. A good time to check the oil level is right after you return home, or whenever you fill up the fuel tank during a ride. Here is a direct link to the post in the CSC blog which describes how to check the oil level.
http://californiascooterco.com/blog/?p=17257
Putting 1.7 quarts of oil in the engine has worked well for me.
Old 07-17-2015, 02:24 PM   #3897
I now fill the engine oil using the slotted cap. The oil goes in very fast, and I don't need to worry about getting burned by the hot exhaust header.
Old 07-17-2015, 02:34 PM   #3898
My engine rpms have increased a bit, but not excessively. My gas mileage has remained at 70 mpg. If you lug the engine, you will hurt fuel mileage. Basically, the 13T sprocket allows my engine to keep operating in the ideal rpm range, which increases power and maintains fuel mileage.
A lighter rider operating at sea level will probably prefer the stock, 14T C/S sprocket. However, heavier riders, such as I, and riders living far above sea level will definitely prefer the 13T C/S sprocket.
I think it's great that CSC is going to stock the 13T C/S sprocket. It is very easy to experiment with this sprocket, and see if you like the increased torque.
Old 07-17-2015, 05:53 PM   #3899
detours   detours is offline
detours's Avatar
Good news that CSC will carry the 13T. I'm definitely going to order one! Wish I already had one. I'm going on a long ride through Rocky Mountain National Park, Grand Lake and Winter Park tomorrow. Those elevations and grades will definitely put the RX3 through its paces.
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 07-18-2015, 12:00 AM   #3900
I installed a SpeedoDRD, so my speedometer is accurate. I calibrated my speedometer with a GPS unit.
At an actual speed of 65 mph, my tachometer reads 7,600 rpms. At an actual speed of 58 mph, which probably reads 65 mph on the 'optimistic' stock speedometer, my tachometer reads 6,800 rpms.
Search this Thread:
Advanced Search
Display Modes
