Old 08-17-2015, 03:27 PM   #4036
All true, PCG. The variable is the amount of torque that is produced by the engine; there is a tipping point, where the torque of the engine will no longer be able to carry the vehicle at the same speed.
Put another way, if you slowly raised a gear ratio (which means lower numerically) one rear sprocket tooth at a time, you'd observe a faster and faster top speed, and then it would begin to drop off. There will be a certain final drive ratio that provides the max speed for a given combination.
Old 08-17-2015, 03:46 PM   #4037
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
That's why they oftentimes have to push (or tow) "Land Speed Cars" to get them started, because they have a huge gear, that even their high HP engines can't overcome at slow enough speed to even get started out of first gear.
Old 08-17-2015, 04:12 PM   #4038
pismocycleguy   pismocycleguy is offline
Banned
But the "power band" RPM range of the engine does not change with each tooth of change in the sprockets? That is the job of the multiple speed transmission, to match the power band RPM's to the desired MPH's.
And yes, it takes more engine torque to turn a bigger gear ratio.
Old 08-17-2015, 05:24 PM   #4039
detours   detours is offline
detours's Avatar
It's true that an engine's power band (efficiency) is independent of its gearing. But whether the power it generates is accessible to do work depends entirely on the gearing.
For example, in first gear on level ground the 13T sprocket allows the amount of torque that exists at 3500 RPM to move the bike. Using the 14T, there isn't enough torque at 3500 to get moving ... you have to get above 5500 RPM to find enough torque. On a hill, you may have to hit 6500. On a really steep hill, there may not even be enough torque to start moving with a 14T sprocket.
So strictly speaking, the engine's power band didn't change with the 13T sprocket ... it just feels like it because the lower part of the band is now usable.
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 08-17-2015, 07:05 PM   #4040
Banned
Thumbs Up Exactly
Originally Posted by detours View Post
It's true that an engine's power band (efficiency) is independent of its gearing. But whether the power it generates is accessible to do work depends entirely on the gearing, the engine's power band didn't change with the 13T sprocket ... it just feels like it because the lower part of the band is now usable.
Exactly my point.
Old 08-18-2015, 12:58 PM   #4041
rjmorel   rjmorel is offline
rjmorel's Avatar
FYI. I installed the 13T yesterday and took it down the highway. At GPS 60mph, speedo was reading 69mph. 7500 RPM. With the 14T if I remember right GPS 60mph was 72mph on speedo and 7000 RPM. So still very highway ride able. I will give it a good test at end of month going down to the Sound Rider Rally in Hood River , OR. Anyone else going to go to it? Or will I have Clement Salvadori all to myself rj
Live Zong, and Prosper
Old 08-18-2015, 03:19 PM   #4042
rtking   rtking is offline
Great to hear that the 13T counter sprocket is making the bike much more tractable around town. I'm curious about top end, freeway riding speed impact from the sprocket change. Will the bike still do a GPS measured 84 mph even with the 13T sprocket?
Old 08-18-2015, 05:32 PM   #4043
While riding the interstate highways, the ability to sustain a top speed is more important than a transient top speed which drops rapidly while you climb a long incline.
I think every RX3 owner should experiment with the 13T C/S sprocket. After all, it only costs $12.95. You won't know whether you like it or not, until you try it. Some riders like me will prefer the 13T sprocket in all situations. Others might prefer the 13T sprocket in some situations, and some will prefer the 14T sprocket in all situations.
Old 08-19-2015, 12:23 PM   #4044
In case you haven't heard, Motorcycle.com just awarded the CSC Cyclone RX3 an honorable mention as the Best Motorcycle Value of 2015.
http://www.motorcycle.com/features/b...e-of-2015.html
With the following list of stock equipment, this bike is indeed, an excellent value for the money.
U.S. Delphi Fuel Injected Engine
Water Cooled Engine with 2 Radiators, and 2 Radiator Fans
6-Speed Transmission
Superb Clutch
Excellent Headlight (with H4 bulb)
Engine Guards
Tall Windshield
Siemens Digital Dashboard
LED Turn Signals and Brake Light
4.2-Gallon (16-Liter) Fuel Tank
Locking Gas Cap
Integrated Luggage with Locks
Perimeter Engine Frame
Strong Sub-frame to Support Heavy Loads
Stainless Steel Exhaust Header
37mm USD Forks
Progressive Lower Shock Linkage
1-inch Fat Aluminum Handlebars
Skid Plate
Black Anodized Hubs
17-inch Rear Wheel with an Excellent Cushion Hub
Disc Brakes on Both Wheels
Braided Stainless Steel Brake Lines
Hydraulic Brake Light Switch on Rear Wheel
110-Link, Size 520, O-Ring Drive Chain
Wide, Serrated Foot Pegs with Rubber Inserts for both Rider and Passenger
300-watt Stator Output
Deluxe Wiring Harness with two Fused, Switched, Auxillary Power Connections
2-Year Warranty for Parts
1-Year Warranty for Parts and Labor
Old 08-21-2015, 09:51 PM   #4045
happycamp3r   happycamp3r is offline
Hi Everyone,
I'm a longtime lurker, first time poster here. I don't have an RX-3 yet, but looking to take advantage of CSC's good buddy program. Is there anyone out there in Northern California thinking seriously of getting an RX-3? We could ship them to the Redding depot and I could trailer them to our residences. Let me know if any of you are interested!
Thanks!
Old 08-21-2015, 10:10 PM   #4046
3Speed   3Speed is offline
Thumbs Up prototype seat
I just got off a 90 mile plus ride (mostly highway, some twisties) with the CSC prototype new seat, boy, let me tell you, it made such a difference, it easly doubles, if not tripples the distance traveled before you start to feel un comfortable.
It is slightly taller setting, flater, wider top, and has softer cusion where needed.
It is 100% improvement over the stock, narrow,hard, hammock shaped seat,
As soon as they have the seats available, I will be the first in line
Old 08-21-2015, 11:20 PM   #4047
jjn   jjn is offline
Just got a quote to ship one of these to Hilo Hawaii. $700, and I would have to pick it up at the shipper. For the same price a guy has his 2014 XT250 for sale. 1236 miles.
Jon, in Keaau, Hawaii
Old 08-22-2015, 12:54 AM   #4048
Originally Posted by happycamp3r View Post
Hi Everyone,
Thanks!
Welcome; we are glad you joined us. I hope someone takes you up on your offer.
Old 08-22-2015, 12:55 AM   #4049
Thanks for posting the good review. How did the new seat affect saddle height?
Old 08-22-2015, 12:58 AM   #4050
The Yamaha XT250 will be a better dual sport bike. The Zongshen RX3 will be a better street/adventure bike. Since you aren't likely to take many multi-day trips on any of the islands, you might be better off with the XT250. Of course, the cost of ownership will be less with the Zong.
Search this Thread:
Advanced Search
Display Modes
