#31 |
detours, I've built up a Warp 9 for a rear on my KTM and it not too difficult if willing to spend the time and be methodical. I would say it's certainly easier then building up a bicycle wheel. I have every intention in building up an 18" rear and 19" front for the Zong soon. I was hoping to have it done before the Baja ride but that just not going to happen in time.
I'll try to past some pics tomorrow. |
#32 | |
![]() ![]() ![]() The Warp9 rims do have a very small rib inside the flange, but I don't know the purpose of the rib. This rib is perhaps one millimeter high at most, and appears to be corrugated by the machine tooling as the rim is bent into shape.
#33 | ||
If you do some research on the internet, you can certainly teach yourself to lace and true a wheel. As 3banger states, you should take your time, be methodical, and make small adjustments. I also recommend you invest in a good truing stand. ![]() If you don't feel like doing the job yourself, for whatever reasons, it is best if you can find a local shop to do the job. Having the job done locally will allow you to save a lot on shipping costs, instead of sending the hub to Buchanan's, or another wheel builder. ![]()
#34 |
how do you like those shinko 244 tires? an what kind of lifespan are you getting form them?
-whatever you do, just be awesome. - 2008 Kawasaki Versys - 2016 CSC TT250 |
#35 | |
Dan CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650 |
#36 | |
#37 | |
![]() My Kenda, K270 front tire lasted almost 13,000 miles before I replaced it with a a Shinko 244. The K270 would have lasted even longer if I had flipped it every 4,000 miles. ![]()
#38 | |
#39 |
Hey Spud....need your feedback on this. I just laced up the 17" Warp 9 rear rim this afternoon. I am a bit concerned about the spoke length using the original RX3 spokes.
I have it trued up but most of the spokes have about 3/16" of thread showing above the nipple. This equates to about 6 or 7 threads on the spoke itself. Can you tell me if this is about the same result that you had and if so....apparently you have not had any issues. Just concerned about not having more threads engaged in the nipple. Thanks for your feedback! |
#40 |
The rule of thumb for us machinists is that in steel anyway, once your threaded in more then the length of the diameter of the bolt, you will twist the bolt in 2 and not strip the threads. So on a 1/4" thread once you have more threads engaged then 1/4" it should break bolt in 2 and not strip the threads. Brass may be different ???? rj
Live Zong, and Prosper |
#41 | |
#42 |
Okay, so I went ahead and contacted Buchanan's Spoke customer service to get the straight skinny. They said that if the threaded portion that is engaged is 1.5 times the diameter of the threads....maximum strength has been achieved.
So in the case of the RX3, the spokes are 4mm diameter....so any engagement more than 6mm should be sufficient. So Spud and I should be good to go as I probably have about 7 or 8mm of threaded engagement. |
#43 |
Yes, I haven't had any problems whatsoever.
#44 |
Greetings SpudRider.
I'm switching my rear and front wheel to larger sizes. Rear 15 to 17in, and front 18 to 19in. I purchased the rims, but I don't know the length of the spokes. Did you, by any chance, measured the length of the rear spokes? I'm unable to take the rear hub to the shop due to various logistic and physical location limitation. Really appreciate it if you have any information regarding the rear spokes length. Thanks!
People sit on an exploding, volatile, fast-moving two-wheeled killer machine, and call it "enjoying the moment". ![]() No wonder aliens never make contact with us. ![]() -A Zong rider- |
#45 |
I used the rear spokes which were laced to my original rim. You can purchase these spokes from CSC, in Azusa, California. The rear wheel uses outer, and inner spokes. Both spokes are about 148 mm in length.
