#16 |
Just found the 16tooth one on Amazon for just under $10 shipped. Thanks, Weld!
#17 |
You're welcome. I hope that works for you.
#19 |
when you change sprockets is a new chain needed as well?
#20 |
I have heard yes and no. I am not planning on a new chain for the front, but I would recommend one for a new rear sprocket.
#21 |
anyone know where i can get a new rear wheel for a tmec 200? just really need the hub, could also use rear brake assy.
#22 |
Responded on mychinamoto.com regarding buying a wheel or using my old hub
#23 |
Ok, decide if your current broken hub wheel is 18" (making your front wheel 21"). You should be able to find a replacement wheel like the thread from "lefty" regarding finding a new wheel for his Roketa, and he found one from a United Motors. The rear wheels for Chinese enduros, provided they use the common 21" front wheel/18" rear are pretty interchangeable. Look on CL or other ad sources for people selling older Chinese enduros or pure dirt bikes using the 21"/18" setup.
The other setup the TMECs came with were 17" front and 17" rear wheels. One would get street tires, but either some came with 17" front/rear knobbies, or they came with street tires, and one could order knobbies that fit. If that is the case for your bike, my hub from my wheel with the broken spokes should work for you since it is the 17" wheel. However, I have some broken rear sprocket bolts stuck in the hub, so you will have to remove them, or find someone to remove them. It would probably be cheaper and much quicker playing with my hub than waiting for one. What did Excalibur say about having a whole wheel in stock, vs ordering a hub for you? I paid $140 for my replacement rear wheel (it included a brake disc and stock56 tooth sprocket) including shipping. However, check to see if you have the more common (for Chinese enduros and dirt bikes 21"/18" wheel setup) which would enable you to find one easier.
#24 |
guys i use the untied motors sprocket same spacers fit perfect had to take 3 links out of my chain hour and a half ready to roll united motor brakes are bigger and i like that lefty guitar aka kman
