Old 04-03-2017, 07:16 PM   #1
Slaphappy   Slaphappy is offline
Confused on CDI
I have the Tao Tao Rhino and I am looking to get a spare CDI to carry with me.
With the engine off and the key in on position the lights come on. I'm assuming that makes it DC. But When I took off the box and compared it to parts I'm seeing on line it matches the AC plugs. 6 pin square.
How do I know if I need AC or DC?
Old 04-03-2017, 07:57 PM   #2
Bruce's   Bruce's is offline
I just googled the rhino CDI hoping for a picture ,and excalibermotorsports on eBay has them OEM for $12.95 ,for that money I would just order a few and not be bothered worrying about if it's ac or dc .
Old 04-03-2017, 08:44 PM   #3
humanbeing's Avatar
Originally Posted by Slaphappy View Post
...How do I know if I need AC or DC?
AC or DC headlight are nothing related to CDI !!!
Check the stock wiring:
AC: [key ON position]Voltage is NIL until spinned the starter (>40V) | The wire connects from stator dircectly| often in black & red
DC: [Key ON postion] There's ~1?V | The wire bonded to battery / rec
Old 04-03-2017, 08:54 PM   #4
Mudflap   Mudflap is offline
I would recommend getting one from Eagle ATV parts or another place that sells actual Taotao CDIs. I tried 3 different ones from ebay that were advertised to work on the Taotao 250 and none of them worked correctly. All too advanced.
Old 04-03-2017, 08:54 PM   #5
Darth Racer's Avatar
I still haven't ordered a spare CDI for mine yet. Want to get a couple of other spare parts like the rectifier/regulator etc.
Only thing I do know is stick with a OEM CDI unless you can get a confirmed reply of a non OEM one that works. Read in a lot of places upgraded ones don't work.
Old 04-03-2017, 09:03 PM   #6
Thanks!
Mine looks like this..
https://www.vmcchineseparts.com/coll...c-250cc-engine
Going to check Eagle for it.
Old 04-03-2017, 09:10 PM   #7
I need to slow down. Working 60 hour weeks and trying to fit this in is going to get me in trouble. I got home from work and took the CDI out with a flashlight in mouth. Put it back in the same way and it wouldn't start. I was afraid I bent a pin or something so I took the box off and put it back on about three times.
Tried pressing the kill switch 20 times and finally realized I had taken the plug wire off to give me more room. I wouldn't have been able to sleep if it hadn't started.
Old 04-03-2017, 09:45 PM   #8
The $12.95 one from Excalibur I mentioned is supposed to be an o.e.m. one .
Old 04-03-2017, 11:33 PM   #9
humanbeing's Avatar
AC-cdi
DC-cdi
Ac to dc : It's easy https://translate.google.com/transla...502&edit-text= Isn't it?
Old 04-11-2017, 07:55 PM   #10
CDI from VMC got here. It looks identical but haven't had a chance to plug it in yet. Worth a shot for $5.. if it works I may get a couple.
Still waiting on the carb.. didn't realize it would take almost a month to get it.
Old 04-12-2017, 02:32 PM   #11
Although it looks identical the CDI doesn't work. Shoulda listened and got the one from Eagle.
Old 04-12-2017, 03:15 PM   #12
The CG engines used in Taotao quads must have the trigger coil located in a different place, or a different flywheel, or both. Wonder who the manufacturer is? Read somewhere they are CF Moto but I've seen nothing to back that up.
Old 04-12-2017, 03:47 PM   #13
Even though I've always been told they're junk, I've only had one CDI go bad and it's when the little rubber band broke and it fell on the exhaust of my XMoto. Not cool to smell plastic and then lose power a few miles from the truck.
Now you got me paranoid. I may grab one of these as well. I wonder if the TT250 takes the same one since it's also a CG?
Old 04-12-2017, 08:33 PM   #14
For all I know the one on there may last for years.. just figure having a spare with me is good preparation. Small and easy to carry. Comparable to having extra fuses in my vehicle I suppose.
Only fuse I remember ever replacing was on a cigarette lighter. But dang it..if I ever do need a fuse I got one with me!
Old 04-27-2017, 08:27 PM   #15
I ended up getting one from them. It came today and I can confirm it works. Thanks for the info. Carb came today...just need to find time now.
