#826 | |
Very good thinking I believe this is the final fine tuning that this carburetor needs. With Thumpers jetting plus shim and now the addition of an air screw for less than $10 you have a very good carburetor. Great job!! |
#827 | |
Templar M 250
I bought the Templar M, which the only thing I can tell that’s different from the X, is the adjustable shocks, and the 6speed. It came with the back rack and passenger pegs and everything to tag it. I won’t ever put it on the road, so the 5 speed works for me. A couple of questions, if I could get some help please. This is a great forum. The videos on YT are showing about 3 finger widths of chain slack? The thread above is saying less then 1/2”? I’m not really doing any huge jumping, but 1/2” seems tight. Does anyone have part numbers to for the adjustable front forks and rear shock? What else should I look at modding? Is the chain 120 links, if like to get an o-ring chain. |
#828 | |
Congrats on the M. Yes, it is going to be FUN!
I am still using the original chain on my 5 speed now, AND the 49T rear sprocket. I did switch to a 14T front sprocket, but it required grinding the cast-in alloy mud gaurd down, so I don't recommend it. You can drop a few teeth in the rear sprocket instead. But I would recommend keeping the gearing down low since you are going to be riding mostly offroad. I prefer about 1 inch of flex on the chain (~2.5 cm). More is not needed. BUT, buy a can of Champion chain lube spray grease (or equivalent). Hang the chain from baling wire from the ceiling. Lay a rag towel under it, and if you have a latex or vinyl glove, put it on your left hand and cuddle the top of the chain with that hand... spray the piss out of it, slowly moving down the chain. Rub it in, top to bottom. Clean up the mess ![]() NOTE: I removed that stupid brush guard from in front of the rear sprocket. Leave it if you think you will be riding through big bush. I just don't like it ![]() Quote:
#829 |
Insurance??? please post
Please post your insurance company name if they have given you liability insurance on the Templars.
I had to call with the MCO in hand since the manufacturer is not in their database, and the VINs do not get recognized. Tell them the manufacturer is Zuumav (not Honda ![]() I had insurance in place on a Suzuki Bandit, so I was just adding the Templar to the policy. They added it for about $30-$35 annual premium. I was amazed. As a stand alone vehicle on the policy, it will probably be higher. Last edited by Thumper; 11-12-2024 at 07:55 PM. |
#830 | |
#831 |
Out of the crate tire pressure
Going to skip the photos on this, just a record for the curious.
Rear - 17 PSI out of the crate Front - 6.2 PSI out of the crate
#832 |
Today I dedicated to getting all the torque on the rear and front rim spokes dialed in.
First I got the bike racked so the front and rear tires could free spin. Then my spoke torque wrench kit came in with one of the extra tips I ordered (6.0 mm). I still have a 6.2mm in transit waiting to be delivered but word to the wise if you have one of these bikes the front and rears are actually the same size. I could use the 6.0mm tip on both the front and rear spokes to do the toque job today. I am very glad I actually did check and uniform the torque settings, they were all over the place out of the crate from loose to already at 35 inch pounds or higher! My method was start at the air valve. Torque only a quarter turn, then followed the pattern skip two, torque the 3rd. Because the out of the crate torque was all over the place I did multiple rounds, doing no more than 1/4 turn until the torque wrench clicked at 35 inch pounds. Then I switched to the next rim on the bike and worked on getting that uniform to 35 inch pounds. Then I went back to the back wheel after it had settled and hit it again at 35 and found a few spokes that had slackened on tension and brought them back to 35. Then I did the second round on the front. I then spun both rear and front wheels on the bike observing for lateral and radial run out and and saw none (dirt bikes have a looser 2mm design tolerance so no need to break out the dial). ![]() With 35 dialed in and settled in I then brought front and rear spokes up to 45 inch pounds of torque. Doing a round of skip two do the third and making sure I made it all the way around every spoke. (usually to be sure I wait until the pattern lands me one rotation from 1st spoke next to air stem to the 2nd spoke next to air stem to the 3rd spoke next to air stem and then the 4th rotation it resets back to 1st. I then switched to the second rim and let the 45 inch pounds settle into the first rim. A second round of both wheels and I call the "initial" job done. ![]() After the first ride and a few rides later I will hit all the spokes again but it should go A LOT quicker the next time around. I'll keep hitting it until they settle and stabilize and I find no more spokes that have slackened off.
#833 |
The price of threadlocker has gone up a bit since I last bought some so I went to my local Harbor Freight to switch brands.
I picked up both blue and red threadlocker at 1/4 of the price of loctite. While I was there I had the idea of buying a Stubby Screwdriver and then grinding the flat blade size down to fit the Air Pilot screw I just recently freed up on my carburetor. To fit inside the frame I was then going to take an angle grinder with cutting disc and cut the handle side of the screwdriver mostly off leaving a short stub to grab and turn. I decided against the single stubby screwdriver as a few dollar more and I could get the whole screwdriver set (one of HF's cheapest sets). I never bought one before and had always gotten the better sets. I am so glad I did buy this instead! The very first screwdriver I took out on opening the pack I out of curiosity tried on the air pilot screw hole on the carburetor. Perfect fit! no work to do! I love it when a plan works out better than I had planned it. ![]()
#834 |
I live at an elevation of about 800ft. How likely is my Templar to start up out of the box? just curious if I should absolutely replace carb or whatever. want to plan.
#835 |
Every carb is different even two of the same bikes. It willl likely start up just fine but be lean out of the box.
A variety pack of different sized idle and main jets for the carburetor that comes with the bike will be under $8 from eBay. A set of two M4-.7x16mm socket cap screws to replace the break-off bolts on the carburetor bowl will be $1.30 from Home Depot.
2022 1/2 Templar X 250 - 6 gear model - 13 Front / 40 Rear Sprockets - #42 / #120 Jets - 1mm thick nitrile O-ring needle shim (removed) - Kenda K761 Dual Sport Tires - Sedona Standard Thickness Inner Tubes - Stock OEM battery, carburetor, spark plug still going strong - https://youtu.be/dhAYEKH-jFQ Last edited by Texas Pete; 11-26-2022 at 03:10 PM. |
#836 | |
years ago I took off the top of my Lifan carb and moved the needle but that is all the carburetor knowledge I have in this world... I am not sure about being able to perform surgery on the stock carb. |
#837 | |
Good inexpensive Spoke Wrench
What’s a good inexpense wrench and tip set to purchase?
Templar M 250 TaoTao 140 Daring Greatly |
#838 |
How much does a new rim cost, or two rims to replace? A spoke torque wrench kit will cost a fraction of a single rim and you’ll have the tool for life. They all cost the same amount for most of the kits.
At the moment RockyMountainATVMC has them on sale. They got me mine for $18 less than Amazon wanted for the same kit and they gave me faster free shipping. Expect any of them to be around a Benjamin. I’ve seen people use Faast brand but it is a preset torque which is either a plus or a minus depending on what you want. If you just want to pick it up and torque without a thought it’s great. I tried the Warp 9 because it is adjustable torque in case I get to work on smaller bikes as well as larger bikes in the future. Or if I don’t trust the metal being used in a spoke I can lower the torque setting. Most kits have a non torque wrench handle for loosening spokes so that you can keep your torque wrench calibrated longer. I also made sure I got a 6mm tip. I had a 6.1 in my kit but I didn’t try it since 6.0 is a tighter tolerance of fit for my spokes.
2022 1/2 Templar X 250 - 6 gear model - 13 Front / 40 Rear Sprockets - #42 / #120 Jets - 1mm thick nitrile O-ring needle shim (removed) - Kenda K761 Dual Sport Tires - Sedona Standard Thickness Inner Tubes - Stock OEM battery, carburetor, spark plug still going strong - https://youtu.be/dhAYEKH-jFQ Last edited by Texas Pete; 11-26-2022 at 03:08 PM. |
#839 |
I am very unoriginal. I have the Harbor Freight 15” foldable / collapsible tool bag that I have yet to install on the back of my bike. For an around town runabout bike it stays zip tied to the rear luggage rack and provides a rather large amount of storage space when you want to pack items such as from the grocery store or wherever and cart them back home without having to resort to taking a backpack with you. And when not being used it folds completely flat against the rack.
You get them for $8 or $9 from HF.
2022 1/2 Templar X 250 - 6 gear model - 13 Front / 40 Rear Sprockets - #42 / #120 Jets - 1mm thick nitrile O-ring needle shim (removed) - Kenda K761 Dual Sport Tires - Sedona Standard Thickness Inner Tubes - Stock OEM battery, carburetor, spark plug still going strong - https://youtu.be/dhAYEKH-jFQ Last edited by Texas Pete; 11-26-2022 at 07:25 PM. |
#840 | |
Thank you
First road ride X-Pro Templar 250M https://youtu.be/k3kA_JZEGyk Windscreen: EGO BIKE Smoke 18*16 Tinted... https://www.amazon.com/dp/B019Z6VA4Y...p_mob_ap_share 16T 520 front sprocket: WPHMOTO 520 20mm 16T Chain Front... https://www.amazon.com/dp/B0865YF176...p_mob_ap_share Simple, cheap exhaust wrap: Titanium Exhaust Wrap 1" x 16'... https://www.amazon.com/dp/B073ZBF72X...p_mob_ap_share |
