Originally Posted by Zooker89
So after adjusting the valves, I finally put some fuel in and fired it up only to hear it ticking like a time bomb.
I used a .0015" feeler gauge and did the 1/8th turn from snug closed...
I used the old screwdriver stethoscope trick and it sounds like it is more from the intake, but noticeable from both.
So now I have to take it all apart again and readjust...
Any thoughts or tricks would be appreciated.
If you used the 0015" feeler after ~1/8th turn, that is the right setting. The question is were BOTH valves closed on that cycle? It is every other 360 degrees on the crank, with |T (TDC) lined up in the view port.
