Old 04-15-2015, 05:41 PM   #2836
oldqwerty   oldqwerty is offline
AGM battery OEM is awesome.
Won't have to worry about acid spills or fumes causing terminal corrosion or refilling the cells with water. Two of my TWs have the cheap Chinese AGMs from eBay. One is 4 years old, one a year old. The 4 year old battery has sat as long as 4 months without care and fired the bike right up. The newer battery saw a couple weeks use when it was first installed, then sat almost a year, then was moved to another TW whose OEM battery died while the owner was in Afghanistan, and fired his TW right up.
I don't have any friends so mine will have to wander home all by its lonesome.
"Thou shall not Zong" is not a commandment.
Old 04-15-2015, 08:43 PM   #2837
Won't have to worry about acid spills or fumes causing terminal corrosion or refilling the cells with water...
I agree. My Zongshen ZS200GY-2 arrived with a genuine, Yuasa wet battery. That was a very good battery, and it lasted 3-4 years. However, I much prefer having a sealed, low maintenance, AGM battery.
I'm going to slow charge my battery overnight to maximize its lifespan, as described in the video below.
Old 04-16-2015, 01:31 AM   #2838
Plenty of virtual friends here to talk shop with.
Old 04-16-2015, 01:33 AM   #2839
X2; we are glad you joined us.
Old 04-16-2015, 01:49 AM   #2840
detours   detours is offline
detours's Avatar
No objections to the stock RX3 battery, but if the terminals match, I'm going to move my Shorai lithium-iron battery (LFX18A1-BS12) from my V-strom 650 to the RX3. Should save over 5 lbs.
I'll set the RX3 stock battery aside and put the original battery back in the strom.
Red 5 standing by!
2014 Ural Patrol
Old 04-16-2015, 01:54 AM   #2841
A Shorai is a nice weight savings, but the two things I've read are don't let them discharge, and don't let them get cold.
I don't know these things first hand, but it's enough for me to pick a less expensive and more reliable AGM. My AGM batteries have been flawless.
Old 04-16-2015, 02:00 AM   #2842
I shed 9 pounds from my Honda XR650L when I performed my Shorai battery relocation. The battery replacement itself shaved 5 pounds from the bike, and removing the stock battery box shaved another 4 pounds from the motorcycle.
http://www.advrider.com/forums/showthread.php?t=666195
Old 04-16-2015, 02:07 AM   #2843
You don't want to short circuit a lithium battery; they discharge very rapidly, and can start a fire. However, you don't need to worry about the cold. The manufacturers actually recommend placing a lithium battery in the refrigerator for long term storage.
http://shoraipower.com/faq
The lithium batteries also crank very hard during cold weather. I'm sure they crank harder than conventional batteries at the same temperature. I have never had any problems starting my Honda XR650L in temperatures slightly above freezing.
Old 04-16-2015, 10:14 AM   #2844
Can't beat a Chinese AGM from eBay for all around value. Has anyone actually had a problem with one?
Not sure which technology Shorai is using, but as for home assembled ABC LiFePO4 battery pack in my café racer TW, well, when every gram matters, it's the way to go. It's small size allowed a custom air filter box for adequate flow and filtration to protect the engine. However, cold weather requires a specific allotment of thoughtfulness as the pack seems weak. Turn the key on so the lights come on, wait two minutes, then it fires right up. Something about the pack needing to warm up before it will deliver high amps. Keep in mind this engine is 276cc, 11.1:1 compression, and puts down 30.1 horsepower at the tire, so the load on the starter is significantly more than a stock TW. Yes, I expect it to explode at any moment, but so far, it's been a blast.
Avoid lithium polymer (LiPO) batteries as they spontaneously combust when damaged. The smoke and flames add a nice scale touch when I crash one of my RC airplanes.
Old 04-16-2015, 12:18 PM   #2845
Why would I curse nice folks like you with my dysfunctions? No, I'll go away as soon as the new bike excitement wears off, which will be 3 seconds after its first ride, when I kick it off the stand and get it over with. After that, it'll be just me, a RX3, and a road less traveled.
Old 04-16-2015, 03:05 PM   #2846
detours's Avatar
The Shorai has delivered a very strong, consistent start in my V-strom all winter, but I only rode a few times below 35 degrees ... mostly over 40.
Question: Will it matter that my strom's Shorai is 270 amps and most 250cc engine batteries are around 135 amps?
I've always understand more amps in a starter battery is better, but that's more than double!
Red 5 standing by!
2014 Ural Patrol
Old 04-16-2015, 03:31 PM   #2847
Old 04-16-2015, 03:42 PM   #2848
I agree with you and Weld. I installed a Shorai battery in my Honda XR650L because it removed 9 pounds of highly placed weight on the motorcycle, slimmed the rear of the bike, greatly facilitated replacing the left side cover, et cetera. However, if weight and other factors are not a big issue, I really prefer AGM batteries. That's why I only installed a Shorai battery in my XR650L.
Shorai batteries are manufactered from 4 lithium pouches connected in series, instead of ABC cylindrical cells. Therefore, you can easily increase the cranking power of these batteries by simply increasing the size of the individual pouches. The Shorai battery easily cranks the 4-inch piston in my XR650L, even when cold.
Lithium motorcycle batteries are LiFePO4 (lithium-iron-phosphate) batteries. This technology is much less volatile than the LiPo (lithium polymer) batteries used in radio control vehicles. The LiPo batteries are lithium-cobalt batteries, which are very volatile, and quite unsuitable for motorcycle applications.
Old 04-16-2015, 03:45 PM   #2849
You are correct; more cranking power is a good thing. Your Shorai battery will work very well with your Zongshen RX3.
Old 04-16-2015, 04:16 PM   #2850
katflap   katflap is offline
katflap's Avatar
Valve Clearance
Got a 1000 miles in the saddle , time to check the tappets.
This afternoon I started to prepare, I had ran the fuel tank down to 1 bar on the gauge. This turned out to be ok as there was only a little fuel spillage and with the tank placed vertically it stopped altogether.
Did a quick check of the tappets, all on about 0.04mm. Tomorrow I'm going to set them at 0.06mm which should be fun as it's a pretty tight working space.
Here are 2 pics showing the fuel tank connections.
Green arrow - fuel level gauge
Yellow arrow - rain water drain pipe ( takes water from around filler cap)
White arrow - spare connector
Red arrow - fuel pump connector
Purple arrow - fuel line- fuel filter (white piece is just me blanking the end)
