#76 |
I've had a little oil come out the front view port, but it hasn't ever gushed. On the other hand, I never open that port anymore because I use the timing chain ports and it's much easier.
#77 |
Yeah the timing chain ports are the way to go, so much easier. The service manual should have people do it that way, takes the error out of finding TDC.
I always check for a tiny bit of free play in the rockers just to be sure. |
#79 |
Thanx for the post WD ... I did my 500 mile the other day and mine didnt need adjusted. I'm glad to hear someone else went though the 500 check without adjustment - ive worried some that I didnt check them correctly. Ditto on using the timing chain ports as TDC alignment assist.....made it a lot easier.
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
#80 | |
#81 |
I had the brake side exhaust that was the tightest but I didnt mess with it. I'll rest easier after the 1000 mile check.
#82 |
I did my valve check today. Found all 4 at a tight .005" inches.
Thats kinda loose I'd say. Yes I used the cam chain ports and dbl. checked with the T bar regestration on the stator. So I reset the intakes to .003" inches and left the exhaust's alone at the found .005"inches. Figuring they'd get tight on there own? Now I know .005" is way outa spec. but CSC sets 'em at .003" or .08mm. Bike ran very good , so my question is may I leave those exhaust valves at .005" or .13mm? Spec is .04-.06 mm or .0015"-.0025" inches I hope i'm not getting to, you know, 'out there' about all this. Any thoughts or advise? |
#83 | |
#84 |
GSC, you've done Baja so I assume you have some miles on the bike. So we can presume settings have stabilized somewhat. For me .005 inches would be too loose and when I had a chance I'd go back in and reset the exhausts to .003. There is no real advantage to running too loose and it can increase wear over the long haul. Short term won't hurt. I just did my check, 4000 miles since previous, intakes had loosened a bit, exhausts were unchanged. I set intakes at .002 inch and exhausts at .003.
#85 |
Thanks Nova
That's the kinda stuff I wanted to hear. Experienced advise. Actually its a warranty replacement engine w 1k miles Last edited by GSC; 08-19-2016 at 09:32 AM. |
#86 | |
I'll have to see what my second setting tells me here in a couple weeks.
#87 |
In prep for the CSC Baja ride in a few weeks I did all my bike maintenance that will be needed for the mileage that will occur and that included checking/adjusting the valves. I've done the valves many times and have a couple of observations beyond the great tutorials that are given in this and other threads. First, on my bike the intake valves stopped moving with in the first 1500 miles. I check them every time I do valves but haven't had to adjust them sense. I'm now at 4200 miles. The exhaust valves have continued to move but I think they are close to being done. On this latest adjustment one of them was still at .08 and the other was somewhere between .05 and .07 and only took a minor adjustment. I think I'll soon be able to switch to adjusting them every 5K like CSC says. Since it's been the exhaust valves that continued to move, I would know it was time to adjust them as the bike would start dying when riding it, even when warm, when I'd release the throttle quickly. Anytime that would start, I would check the exhaust valves and they'd be at .04. Hope this helps some of the newer owners with what they might expect with their bikes over time.
2017 BMW F800GS Adventure |
#88 |
well after my fifth valve adj. one exhaust valve was tight only have 4000 miles on the zong has only been on one long ride most of the time it makes trips between fishing holes checked them at 500/1000/1500 2500 and found intakes too be a little loose. and exh.were fine Was stalling at idle and wile downshifting found one tight exhaust runs great again it lives at 7500 to 8000 rpms guess i just don't ride it hard enough really love my limited blue they stopped making them just to fast
Peace and Zong Life
#89 |
Too many sources of (dis)information
Just did mine at about 600 miles. I wish I had read this thread first. I read at least twice through the CSC tutorials online and it seemed like a great walk through but didn't realize the shortcomings till I actually had the bike in pieces. I went to a different site to figure out how to remove the gas tank, figure out which direction to crank to find TDC, and other small stuff and about half of the instructions were wrong.
By the way, am I the only one with a runny gas tank? Instead of just catching residual fuel from the fuel lines my entire gas tank ended up emptying out while I was toiling away on the valves. ![]() |
#90 |
Rather than fully removing the tank I simply lift the front end of it and put a 2x4 on end that is about a foot long there which gets the tank out of the way and I don't have to disconnect any wiring or hoses and no fuel spillage.
