02-10-2019, 04:19 PM | #1 |
What is a good battery fir a hawk 250 please
Hi group anybody have any links for a great battery for hawk 250 i dont kno where to start looking
02-10-2019, 06:47 PM | #2 |
Yuasa YTZ7S or equivalent works perfectly. Similar amp hours and more CCA from a smaller battery. It will need some foam blocks for proper spacing to secure in the battery holder. Usually you can find them for around 20 to 30 bucks.
02-10-2019, 07:50 PM | #3 |
I spent some money and got a lithium battery. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It is expensive, but weighs nothing and comes with a battery charger.
Hawk 250 Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler |
02-11-2019, 06:19 AM | #5 | |
I would also not install a lithium battery without first upgrading to a mosfet Reg Rec with the sense circuit eliminated. This will ensure the proper charge voltage across the RPM range with much greater stability. Otherwise the lifespan of the battery could be compromised. Just one example of a decent affordable battery. A couple people on here use this one. https://www.amazon.com/Mighty-Max-Ba...e%2C195&sr=1-6 I use a Gel variant from the same company and have been quite pleased with it so far.
02-11-2019, 07:49 AM | #6 | |
02-11-2019, 07:53 AM | #7 | |
02-11-2019, 09:46 AM | #8 | |
I didnt like that they dont balance charge the batteries, so built my own. I haven't heard alot of complaining or issues with them. I just felt safer about balance charging rather than parallel charging setup thy all seem to use. like any lipo situation they are nice and powerfull right up to the low voltage cutoff. and the recharge rate seem's superior to lead acid by far.
500cc Hawk Project http://www.chinariders.net/showthrea...372#post281372 |
02-11-2019, 11:23 AM | #9 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 02-11-2019 at 01:47 PM. |
02-11-2019, 05:29 PM | #10 | |
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs |
