Old 07-14-2015, 12:25 PM   #3871
rjmorel   rjmorel is offline
rjmorel's Avatar
Originally Posted by katflap View Post
Yeah, it shouldn't really make any difference.
I just wonder why Zongshen bothered especially as this required fitting a longer throttle cable.
good on the longer throttle cable for us, makes raising the handlebars easier. rj
Live Zong, and Prosper
Old 07-14-2015, 07:05 PM   #3872
detours   detours is offline
detours's Avatar
Originally Posted by SpudRider View Post
However, riding at high elevations, the smaller, 13T sprocket holds its speed much better while climbing long inclines above 5,000 feet in elevation. Therefore, I don't have shift as much, and I actually end up going faster.
Around town at 5300 ft, the stock gearing has been fine for me so far. But after break-in, I'll be riding the foothills and trails at 8000 ft and higher. I should get a 13t. Maybe we should do a group buy unless CSC orders a bunch.
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 07-14-2015, 11:50 PM   #3873
DanKearney   DanKearney is offline
I live at 9,200'. I've been riding the bike (Only 500 miles so far) from home up to about 11,500' and down to town at 6,000'. A good bit of that on Forest Service roads.
So far I am happy with the how things work stock. I agree that a 13 tooth CS sprocket would probably make for better response on steep trails at lower speeds.
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 07-15-2015, 12:54 AM   #3874
Cheers,
Dan K.
I've been riding my RX3 for 5,000 miles, and the 13T C/S sprocket performs better under all conditions. I can even ride faster on the interstate highways with the 13T sprocket, since the bike doesn't slow down so much on extended inclines above 5,000 feet in elevation. Ride the twisty back roads at elevation with the 14T sprocket, and you are constantly shifting the transmission, since the stock bike is geared too high. If you weight more than 200 pounds, and ride hills above 5,000 feet, you will never go back to the 14T C/S sprocket, after you have tried the 13T C/S sprocket. If you weigh 150 pounds, and ride flat roads near sea level in Florida, Indiana, Illinois, et cetera, you might prefer the stock 14T sprocket.
Old 07-15-2015, 10:54 AM   #3875
The riders from CSC, China, and Columbia started their 5,000 mile, adventure ride today.
http://californiascooterco.com/blog/
CSC is also developing a nice skid plate for the RX3.
http://californiascooterco.com/blog/?p=17496
Old 07-15-2015, 04:52 PM   #3876
Where'd you acquire the 13t sprocket?
Dan K.
Old 07-15-2015, 11:51 PM   #3877
Dan K.
I bought the 13T C/S sprocket for my Zongshen RX3 at Taobao, which is the Chinese equivalent of eBay. The NC250 (ZS177MM) engine is employed by a number of different motorcycles. Of course, all these bikes also use the same C/S sprocket.
http://item.taobao.com/item.htm?id=39633060740
Old 07-16-2015, 10:31 AM   #3878
cimarronEric   cimarronEric is offline
I got clobbered by Imogene Pass today because I couldn't maintain enough momentum to make it through a set of tricky switchbacks. WANT!
Noooob
CSC RX-3 Cyclone
Old 07-16-2015, 11:44 AM   #3879
rjmorel's Avatar
I feel your pain on the switch backs Cim. I found I had to use a lot of clutch slipping to get through the few sets I've ridden my RX3 through. Not a trials bike for sure. For most of what I do the gearing is fine. Just not hard core first gear technical stuff. rj
Old 07-16-2015, 12:47 PM   #3880
At Colorado elevations, you will notice a definite improvement in the engine's performance with a 13T C/S sprocket.
Old 07-16-2015, 02:04 PM   #3881
3banger   3banger is offline
3banger's Avatar
Any Imogene photos? Did you make it to the top? I'll be riding Imogene pre Imogene running race. My girlfriend is running and I plan to be assiting up top. I rode her XT250 up their last year no problem. I need to get down that way and pre ride it!
Eric, maybe we can get a CO RX3 group 13t sprocket group order together.
Old 07-16-2015, 03:53 PM   #3882
detours's Avatar
Count me in!
Red 5 standing by!
2014 Ural Patrol
Old 07-16-2015, 08:47 PM   #3883
Thanks for the info. My wife's working in China right now, I'll have to get her to do a little buying for me. Got a part number or seller's link?
Cheers,
Dan K.
Old 07-16-2015, 08:48 PM   #3884
Did my first oil change the other day.
I had to put at least 6 oz more oil than the manual calls for into the motor in order to get the oil to show at all in the view window.
Anyone experience this? Where's it all going?
Cheers,
Dan K.
Old 07-16-2015, 08:57 PM   #3885
rjmorel's Avatar
Cheers,
Dan K.
Group buy, group buy, group buy , I'll buy one also from you if you get them, rj
